Interesting as I just had the Koni Special Active installed 5 days ago under my November 2021 MYLR MiC with the original springs. Difference is there but not as much as I hoped for. But! I lowered my tire pressure because I thought that would help too. Now cold 38psi but tomorrow I will increase to Tesla advised 42psi cold and test drive again because of the valve opening story hereInteresting that in one of the Model 3 Highland videos the tesla exec indicated the new highland had "Frequency Selective Dampers"...aka FSD....like the Koni Special Active shocks (formerly named Koni FSD - Frequency Selective Dampening - Shocks).
As an aside, Koni have historically recommended the FSD shocks be run at stock (or potentially HIGHER) tire pressures. This is because, as I understand it, the "valve" opens when it encounters a sharp increase in movement/pressure. This occurs when the car hits a sharper bump. For slow or larger more rounded undulations the shocks stays firm as the valve isn't opened. If the tires are "soft" or underinflated the "sharp" hit from a bump can be muted and the shock will stay in the firmer mode. In short, if the Koni Special Actives appear to be imparting more bumpiness on sharper impacts, try raising the tire pressure a bit to see if it helps. It may very well not, but its an easy test.
Can you confirm if you got all 4 shocks/struts replaced?Interesting as I just had the Koni Special Active installed 5 days ago under my November 2021 MYLR MiC with the original springs. Difference is there but not as much as I hoped for. But! I lowered my tire pressure because I thought that would help too. Now cold 38psi but tomorrow I will increase to Tesla advised 42psi cold and test drive again because of the valve opening story here![]()
All 4 yes. Test drive tomorrow. Stayed home today.Can you confirm if you got all 4 shocks/struts replaced?
Did raising the pressure help?
Now all the shocks have been changed… and I would say that these are good replacement shocks in case of a stock shock failure, but for improvement of comfort not so much. Ride is so close to the stock ones. In higher speeds like in motorway, these feel little bit softer.Well, after a short test drive, I can say that the rear shocks (Koni Special Active's) have more fast rebound compared to "comfort" stock shocks. They will not bounce like the stock ones on MYLR23. Otherwise they seem to be quite similar. But maybe they will soften up with more use. I was looking for more comfort, but these seems to have "sporty and planted feel".
Thanks for the review!Now all the shocks have been changed… and I would say that these are good replacement shocks in case of a stock shock failure, but for improvement of comfort not so much. Ride is so close to the stock ones. In higher speeds like in motorway, these feel little bit softer.
Sorry to say, but lowering tire pressures with FSD shocks have same impact what you would have with stock ”comfort” shocks...
I’m not competely disappointed but I would not recommend these if one is looking for more comfort and I wouldn’t buy them again.
Hi. I fully agree and difference as you say rather small. But! Definitely better on roundabouts and cornering in general. From a comfort point of view they don’t deliver what we hoped for and what YouTube videos tell us and that’s a pitty (understatement) for, in my case €1.500…. I’m in contact with Koni so let’s see what they can do/adviseNow all the shocks have been changed… and I would say that these are good replacement shocks in case of a stock shock failure, but for improvement of comfort not so much. Ride is so close to the stock ones. In higher speeds like in motorway, these feel little bit softer.
I would say barelyThanks for the review!
What about over potholes, broken roads, speed bumps? That kind of thing.
Does it smooth those out any?
On broken roads or potholes, I don’t see any difference or lets say that I really want to see a change to better but.. I`m not sure about it. These have slightly stiffer rebound setting so after a speed bump, the rear bounces less which is good.Thanks for the review!
