Here's what I'm considering and have learned at this point. This might be beyond the scope of this forum but would appreciate your input. I've watched (low bit rate) youtube videos on breakers; the most helpful has been The Spruce with articles and good videos.
This is what I've read:
- Romex is not for outdoor use which is what I have (my situation is to run 20' under covered deck - mice are my biggest concern)
- Don't run romex in conduit due to heat build up.
- GFCI/AFCI is a must as far as I'm concerned
A few possible options on this project:
- Replace the 20 amp double pole breaker with a 50 amp double pole breaker, install new 50 amp wiring and conduit, install a 14-50 exterior outlet.
- Keep the existing wiring, install exterior 6-20 outlet, buy Tesla 6-20 adapter included in expensive adapter package.
- Keep the existing wiring, install exterior 14-50 outlet (to be run at 16 amps max) so I don't have to buy the 6-20 adapter.
What I'd like to know is what limits the current to 80% on 20A outlet - the adapter? I'm guessing I would need to manually limit the current to 16 amps if I use the 14-50 adapter with 20 amp circuit via car software - which isn't terribly reliable I've learned in my 10 years with the MS.
