... your regular scheduled programming
This shouldn't be true. Plugging one of these into a car expecting three different phases will result in 0V differential between phases; it shouldn't let out the smoke, but rather things will just not work if they have electronics that use L-L instead of L-N. Is there anywhere I can read about why they let out magic smoke?
(Please excuse the crudity of this model. I didn't have time to build it to scale or paint it, but you get the idea.)
AC? I've never seen over 118 kW DC at a SpC.
Same here.
I now take that back... I've seen 122 kW in three records.
And in the latest particular case, climate control was not on - so I believe the entire charging current was going to the battery without anything being drawn off immediately.
I suggest re routing power through the deflector dish, and shunt the plasma through the bisard collectors before jumping to warp.
thats all I got after reading all this. I'm "tapped" out.
I'm convinced from a previous life that ties cut off blood flow to the head.
I am the person who saw the magic smoke when I tried to charge my Zoe with a Tesla UMC + Blue Commando adaptor.
The problem arises in the interpretation of pilot signalling on a Type 2 connector. If the EVSE signals a 32A limit to the car, does that mean that it can draw no more than 32A from each L pin (Renault Zoe interpretation) or that it can put no more than 32A on to any of the 4 power pins i.e. including the neutral (Tesla interpretation).
I believe most S/C cabinets are 120kW, but the newer ones are all 135kW. So it may take going to a new site to experience the higher rates.
Basically if you give a Model S the same phase on all 3 of its live pins it draws 10.66A on each phase making 32A on the neutral, but if you give the same to a Zoe it pulls 32A on each live pin, which puts 96A on the neutral. The result in my case was a fused (closed) contactor in the UMC, and magic smoke (probably a safety fuse on the N wire) in the Zoe, which had to go back to Renault for repair.
I don't think it's an unfair assumption on Renault's behalf. You have a 3 phase connector, with a clear design intent for 3 phase (or we would be using Type 1's), and labelled L1, L2, L3 + N. Theoretically you don't even need a neutral, and who knows someone might come up with a design which doesn't need one at some point in the future. (And in fact Renault might not, but we will have to wait for someone with wk057 or Ingineer or JRickard's skills to dismantle one to find out for certain )
I think we should all team up and roll a Model-S specific board with logging, MITM, etc. No need to make it Arduino "shield" compatible. 2 CAN busses, one on the PT bus, with jumpers to select which bus the 2nd CAN xceiver is on. Micro SD slot. Maybe even a WiFi module on the back so it can be accessed remotely without opening the dash.
Thoughts? Who is interested in such a thing?
Ok, I got it now. The Zoe expects the current to balance out among the phases, which means the neutral current should be close to zero. It's likely fused at a current that would allow for the failure of one phase and it was exceeded excessively.
In theory, if the electronics were designed for L-L voltage (400V) instead of L-N voltage (230V), you'd be correct - no neutral needed. But the prevalence of 230V nominal electronics, and the added expense of redesign for higher voltage, makes it a more costly proposition.
If that doesn't work, then remember to reverse the polarity! LOL
