I installed my spare nose cone with the lighted T. Here’s how it was done.
First, the nose cone with the lighted T was prepared and tested on my workbench. It was in ready-to-install condition. All of the wiring has spade connectors for easy plug and play connections.
My carbon fiber wrapped cone was removed following standard procedures: loosen one of the upper right or left corners with a plastic pry tool and the rest pops out. Easy to do.
The all of the black plastic trim around the frunk has to be removed to provide easy access to parts and ways to hide the wiring once it’s all connected. All of this stuff just snaps out.
Here's what I have behind the nose cone. The radar detector receiver is to the left on the cross beam, my EZPass license plate transponder is on the front center of the cross beam, and plug in RJ 45 connections are on the right and left top of the cross beam to connect the laser jammer transponders. The GPS receiver for the radar detector is to the left of the EZPass transponder.
The most critical step is removing the space around the center clip receiver for the spring clip in the top center of the nose cone. I thought this was metal but it’s actually chromed plastic, which makes it easy to cut with a Dremel tool with a cut off tool attached, as shown. The rough red lines represent the area to be cut out. This is essential so that the printed circuit board connecting all the LEDs and system wiring will fit. Without cutting this out the nose cone would not fit flush at the top.
Here’s the backside of the nose cone before it was attached.
You can see that all of the wiring was already in place an taped down. The only connections to be made were for power (from the TAP-A-FUSE lead) and ground. As I had attached spade connectors to both ends of the appropriate wiring this was just a matter of pushing the leads together. I used a calk gun to pump in black silicone calk to waterproof all of the holes in the nose cone for the LED leads. I also taped the back of the PCM to cover all the solder connections so there would be no risk of a short.
For power I tapped into a fuse with TAP-A-FUSE, as shown, and ran the lead to the nose cone under the Frunk plastic trim. I loosened one of the many 10mm bolts attached to the frame to make the connection for ground.
After making the ground and power connections I snapped the nose cone in place and use the remote to turn on the T. Voila! It looks much better in person than in the photos. In fact it’s quite striking. The reflection off the V under the T is not nearly as bothersome as it was in my bench tests a few weeks ago.
Here a number of photos of the T under varying light conditions, from full daylight to near-darkness. I didn’t have time to shoot a video, so I’ll do that tomorrow night.
My next version will use translucent white Plexi, which will reduce the hot spots (although these are not as big an issue as I thought they’d be). I should have that version ready next weekend.
