sorry, I should have read your post more thoroughly :wink:Yep that's right.
There are no CCS cars at the moment, so what is to convert? Are the network owners going to convert to a speculative standard and orphan the existing base of LEAFs and i? Doubt it.
What does that make the chances of a 50kW CHAdeMO adapter being possible (I see the CHAdeMO adapter being even more complicated because of the need to emulate so many pins, with some being analog signals)?If Tesla's plan is to support CCS, we are back to an adapter trailing on the floor. With 100kW on tap, the authorities will never allow it.
Not impossible - just against the regulations.
CHAdeMO is very different to the SAE / IEC Combo standard. ... It will certainly require a different EVSE control board.
Then the best thing that Tesla can do is to:
- Support 44 kW three phase, to let their European customers use the Type 2 socket of the European CHAdeMO chargers
- Support J1772-DC and IEC 62192-DC if at all possible
- Build a network of Tesla superchargers in North America to try to make up for the lack of CHAdeMO support
BTW, I still don't understand why Americans aren't pushing for 3-phase support - I realize that there aren't currently any 3-phase sockets over there, but there is really no reason for that to continue. As we all know, DC chargers require a 3-phase grid connection anyway. Americans could get access to almost the full power of the CHAdeMO charging stations at little extra cost if Tesla would switch to a three phase capable plug and quick charging stations were required to provide "raw" 3-phase power in addition to whatever other interfaces they have.
3-phase AC is the only cost-effective way of supporting charging between 10 and 50 kW. This is the "not invented here" syndrome.
Couldn't it just be that Tesla went for J1772-DC? On Wikipedia I found:I finally found a J1772-DC diagram that shows how it is implemented! It seems only 5 pins from the car will be able to accomplish the connection, that makes the possibility of a J1772-DC adapter very, very high (like I suspected).
I took the diagram from slide 11 here:
http://grouper.ieee.org/groups/earthobservationsSCC/IEEE_SAE_J1772_Update_10_02_08_Gery_Kissel.pdf
In the middle, it shows 6 connections, but both #8 and #3 are chassis ground (if you see slide 10, it shows a connector diagram, and you will see there are two chassis ground). So only 5 is really necessary. #6 & #7 refer to the DC pins. It seems the L1 and L2/N pins are not used if it's a DC connection, but used if the car wants to charge in AC (the EVSE will detect it if there is AC present and switch appropriately). That makes both sides capable of DC and AC charging using the same connector.
Given how this is designed, it kind of makes sense why Tesla went with a 5-pin design with two larger power pins (since the L1+L2/N pins and the DC pins are not simultaneously used). I don't know if the Mennekes version is exactly the same, but it seems like at least J1772-DC should be possible.
From what I can tell, Tesla's socket is just a more compact version of J1772-DC, without the direct backwards compatibility with J1772 (needs an adapter to accomplish that).
The SAE J1772-2009 connector specification has been added to the international IEC 62196-2 standard ("Part 2: Dimensional compatibility and interchangeability requirements for a.c. pin and contact-tube accessories") with voting on the final specification to close in May 2011.[8] The SAE J1772 connector is considered a "Type 1" implementation providing a single phase coupler.[9]
SAE is developing a "combo-coupler" variant of the J1772 connector with additional pins to accommodate fast DC charging at 200–450 Volts DC and up to 90 kW. This will also use Power Line Carrier technology to communicate between the vehicle, off-board charger, and smart grid. They estimate the standard will be approved and released in the first quarter of 2012.[10] Seven car makers (Audi, BMW, Daimler, Ford, General Motors, Porsche and Volkswagen) have agreed to introduce the "Combined Charging System" in mid-2012.[11] In Europe the combo coupler is based on the Type 2 (VDE) AC charging connector maintaining full compatibility with the SAE specification for DC charging and the GreenPHY PLC protocol.[12]
[*]Support J1772-DC and IEC 62192-DC if at all possible
[*]Build a network of Tesla superchargers in North America to try to make up for the lack of CHAdeMO support while J1772-DC/IEC62182-DC has not become available.
It is excruciatingly difficult to put up Quick Charger network. Even with funds available Ecotality is struggling and hasn't put up even ONE CHAdeMO in the last one year. Second, the CCS OEMs have not announced any EVs with QC.
Let us fast forward to 2013/14 and see how it plays out.
- We will have quite a few CHAdeMO chargers finally in place
- We have new near luxury cars like BMW i-3 & Infiniti EV coming up
- Ininfiti EV supports CHAdeMO
- What does BMW i-3 do ? Does it support CHAdeMO or CCS , given there are almost zero chances of a CCS charging network that does not also have a CHAdeMO connector in the next few years - but there are a lot of CHAdeMO chargers without CCS connectors ?
This is the reason why on the ground reality & first mover advantage is important.
Thats is why I prefer to lease ;-).... and then ? .... your resell value of your Modell S went to zero ...
You didn't include a third option: adopt the Tesla standard.- What does BMW i-3 do ? Does it support CHAdeMO or CCS , given there are almost zero chances of a CCS charging network that does not also have a CHAdeMO connector in the next few years - but there are a lot of CHAdeMO chargers without CCS connectors ?
We are back to the connector discussion againI'am disapointed that Tesla move them selfe in a dead end with that small Plug and not enough space to adopt other standards ...
- Charge Port location - George say'd we will be suprised .. well I was , but not in a positiv way ...
- another Tesla unique Plug - again ???
- no space for other standards plugs - why ???
Given how slow the CHAdeMO network is growing in NA, why do you talk as if CHAdeMO will have a huge head start in just the next two years? Tesla alone can top the CHAdeMO network in NA in just one year if they wanted to (I suspect this is what they are planning to do). The only place CHAdeMO has an huge head start is in Japan and some areas of Europe.It is excruciatingly difficult to put up Quick Charger network. Even with funds available Ecotality is struggling and hasn't put up even ONE CHAdeMO in the last one year. Second, the CCS OEMs have not announced any EVs with QC.
This is becoming OT, but doing research, it seems like at least one BMW Active-E has a CCS socket:- We have new near luxury cars like BMW i-3 & Infiniti EV coming up
