@MountainPass I am considering switching over to your comfort coilovers from Unplugged springs. I am finding limited travel in suspension is making the ride too harsh and the Unplugged springs to big of a drop.
Couples of quick questions
1) with the coilovers, is it necessary to replace the camber arms and toe arms? Wouldn’t the camber suffice?
2) what is your recommended drop to reduce wheel gap.,..i read that you are recommending a 30-35mm drop in ride height..which would equate to 1.2 in drop—is that correct?
3). Please provide your recommended spacer thickness
Any other recommendations to allow for a lowered car, but with a softer ride for city driving with not so smooth roads?
Thanks
Just installed my TSportline springs and added 15mm spacers from BLOX Sport. Looking good?
I think it's just the right amount of drop plus offset to balance it.
View attachment 316666 View attachment 316667 View attachment 316668
@Rlee21 Picture below. I don't think that I made a measurement but you can see in post Lowering the Model 3 where I show stock, unplugged and TSportline. One thing I wondered though, when I looked at the stock car, I thought the front was too high, the rear, kind of OK, so much so, I nearly asked the installer to just fit the fronts however, the net result with both is, I think, balanced and the rears don't look too low - which was my main issue with the Unplugged Moderates. TSportline says 1" all round but if asked, I'd say that the rears are less affected than the fronts, I 'guestimate' that the fronts were dropt 1.2" and the rears 0.8" - that's a total guess though. If someone wants to scale the images, we could extrapolate that.
After a morning of driving on the TSportline on highway, new & old tarmac, on virtually unmade roads and fast dual-carriageway, I'm happier than ever, the ride is really good, better than stock, it's changed from Audi S4 to BMW M3, which is to say, from a bit firm and often bouncy to compliant yet un-rufflable. Very happy!
The install was tough. The springs are very solid, my installer had to purchase a more powerful spring compressor to deal with them safely!
@SPYN2NR Lugs were no issue at all, the factory wheels (like most) have a void between the lugs to save weight, that void is 18mm deep and the studs are 26mm so, any spacer of 10mm or more should be free and clear.
MPT - thanks for the info on the lug issue. I’m going to remove one of my stock 18” wheels and see if they’re just like your sport 19’s....@Rlee21 Picture below. I don't think that I made a measurement but you can see in post Lowering the Model 3 where I show stock, unplugged and TSportline. One thing I wondered though, when I looked at the stock car, I thought the front was too high, the rear, kind of OK, so much so, I nearly asked the installer to just fit the fronts however, the net result with both is, I think, balanced and the rears don't look too low - which was my main issue with the Unplugged Moderates. TSportline says 1" all round but if asked, I'd say that the rears are less affected than the fronts, I 'guestimate' that the fronts were dropt 1.2" and the rears 0.8" - that's a total guess though. If someone wants to scale the images, we could extrapolate that.
You mind sharing how much the spacers run you?@dgaultiere Thanks, I've driven about 100 miles over all terranes at low and high speed. Clearance appears to be fine, no rubbing. Others have upped the width of the wheel a lot and not experienced issues that they've reported. With 15mm I think the front is probably as far as it should go with comfortable margins but the rears could take another 5mm easily I think. The wheels do tilt inward as the suspension compresses.
Regarding the spacers, I ordered them by emailing their customer service after filing in the custom order. Long-Story-Short, US Manufacturers like H&R either didn't respond, said they didn't do Model 3 or wanted a huge premium for a special order and even more for a rush! BLOX were excited to make them and produced fantastic quality parts in a couple of days!
Here's the spec: 2 pairs of: 7075T6 PCD 5x114.3 CB64.1, Bolt thread: M14x1.5, Thickness :15mm. That's 4pieces (2Pcs in a Pair).
email Sandy Qin at [email protected] and mention Michael Thwaite's order to jog her memory!
What did you do with your unplugged? Were you able to return it to them.
Thanks! Do you know if they make a slightly narrower spacer with the extended lugs in it? I'm thinking of something like 12mm front and 20mm rear...@dgaultiere Thanks, I've driven about 100 miles over all terranes at low and high speed. Clearance appears to be fine, no rubbing. Others have upped the width of the wheel a lot and not experienced issues that they've reported. With 15mm I think the front is probably as far as it should go with comfortable margins but the rears could take another 5mm easily I think. The wheels do tilt inward as the suspension compresses.
