From that last comment (which may not have been directed at me) I kind of feel like you think my motive is to denigrate Tesla, and that's a little upsetting. They already have the best handling & highest performance EV on the road, I just want them to have the best efficiency too, and to eliminate annoyances. I think everyone knows Tesla has some big problems to deal with (not just vampire drain), and the best way to deal with these things is to accept and understand them, identify a solution, and fix them. That's just life; a continual series of problems. These things WILL matter in a competitive market...whenever that comes. I'm not holding my breath on competitors just yet.
For me, it's not the cost of the vampire drain that is a concern; I have free charging at work, I have some solar at home, and I have FUSC. For the next couple years, I get $500 back or whatever from SDG&E each year for
each EV I own (which is now a total of 3). It's more the idea that it is destructive to the vehicle and the environment, for no clear benefit that has been explained to me (I'd love to hear from a Tesla engineer).
I like to hang onto my cars for a while. I had my STi for 14 years and did all of my own basic scheduled maintenance, plus a couple of minor unscheduled failures. So, I want a car where everything is set up to last as long as possible.
What I understand about vampire drain (I've said this before):
1) It wears out the contactors. (I believe this requires the HV battery to be dropped out, to replace them?)
2) It wears out the 12V battery to the best of our knowledge.
3) It adds extra wear to the HV battery.
So, I don't think vampire drain is HELPING me with reliability.
More to the point of this thread, let's talk about driving efficiency.
Here is my most recent result.
Special notes:
1) I have the Tesla Stats app. I will disable it because I had a vampire incident yesterday. Nothing to implicate the Stats app, really, but just to make it as Tesla intended, it makes sense to disable it for further discussions here.
2) The following data includes 500 feet of elevation gain. So we need to subtract 800kWh from the usage. (PE = 4250lbs*9.81m/s^2*500ft)
3) Halfway through this period I turned off the data reporting & cabin overheat protection.
4) I spent no time sitting in the car and not driving. I just drove.
5) I used ZERO HVAC. No fan. Just off. I used zero pre-heating. I used seat heater and rear defrost briefly.
6) It's been about 55-70 degrees in San Diego.
7) Obviously accelerated briskly on several occasions. I was aggressive and even braked a couple times (worse than my typical driving just because I caught a few lights at the worst time).
8) Version 50.6
9) I did not check the car status remotely.
I charged car to 254 miles on Monday evening at work (moved it to the chargers a few hours after I got to work), then left it at work, rode home on my bicycle, rode back to work this morning. Lost about 12.5 miles overnight (that's a record for me). All the doors were closed & latched properly. I honestly have no idea what happened - the LTE signal is weak in the garage at work. It had no WiFi connection. Maybe it was the Stats app. 50.6 is quite new; could be related. (It has been refusing to open the door for me more, with that update. So maybe higher vampire, reduced functionality. Who knows.)
I completed driving today having 210 rated miles remaining, with 16.8 miles of real driving.
Just summarizing calculations:
Actual battery-to-wheel efficiency:
(254 rated mi - 210 rated mi) * 242Wh/ rated mi / (16.8mi) = 634Wh/mi (634Wh/mi - 800Wh/(16.8mi) =
~586Wh/mi (elevation corrected))
Indicated battery-to-wheel efficiency:
350Wh/mi (elevation corrected would be
~302Wh/mi) (This is more or less a normal metered efficiency for me - slightly worse than normal, as mentioned. I can probably get to 270-280Wh/mi if I'm careful.)
Wall-to-wheel efficiency (using prior Chargepoint results, see earlier posts):
586Wh/mi / 0.86 =
681Wh/mi (MPGe 49.5) (Right now, I expect it will take about 12.35kWh to charge back up to 254mi - I'll confirm that tomorrow - that's actually the final necessary piece of data here...real numbers will likely be higher because I have to drive back to work still...plus vampire tonight).
Picture evidence below, lest you think I am making it up!
Obviously, on average I do a bit better than this. That vampire was an outlier. Again, YES I WILL DISABLE THE STATS APP. Just to see if I can get to the promised land. Is there anything else I need to do? Any magic menu items to disable? I'm not going to disable mobile access - I assumes that disables the phone key function (could be wrong)?
View attachment 373069 View attachment 373070
