Main screen reboot while driving
Discussion in 'Model X: User Interface' started by lundse50, Aug 1, 2017.
  1. lundse50
    lundse50 Member
    Wilmington DE
    Has anyone had their system reboot while driving? I was in Virginia on 95 the other day with navigation on when my screen went blank and rebooted itself. It came back in a few minutes and it is have been find since. Comments? Thanks
  2. wdolson
    wdolson Active Member
    Clark Co, WA
    It happened once when I was on the way to the service center (ironically). I had switched back and forth between the browser and navigation a few times. When they pulled the logs they found the memory got corrupted with the screen switches and it caused the screen to crash.
    It only happened once.
  3. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    The car does not use the main screen or the dash screen. You can reboot it at your pleasure while driving. If something doesn't seem to be working, the first thing one would think of would be to restart the screen, and you don't have to stop to do it. I have done it a couple times. No Big Deal.
  4. bcampbelllds
    bcampbelllds Member
    North Dallas, Texas
    This happens to me once or twice a year. I have no explanation for it. I kid with my wife that it's Tesla updating my car remotely.
  5. verygreen
    verygreen Curious member
    TN
    Well, you lose A/C, so there's that uncomfortable minute while it's not working if it's hot outside.
    probably some other somewhat minor stuff.
  6. depeche
    depeche Member
    Fresno, CA
    My Ranger always talks about 2 causes:
    1. Web page that is set to a page that has refreshing content
    2. USB drives in ports
    I have found removing drives or changing the web page does make a difference.
  7. lundse50
    lundse50 Member
    Wilmington DE
    thanks for all your comments. I did have the ports connected and I did lose the air conditioning for a few mins... Navigation still worked on the small side display that helped because my exit was coming up. Sounds like either a physical memory issue or a coding issue. thanks again
  8. cybergates
    cybergates Member
    So Cal
    lately I've been getting main screen reboots probably every 1-2 weeks - usually streaming music freezes up and then reboot. Everything good after that.
    Do I need to show it to them?
    EDIT: I do use a USB key for music
  9. tllt
    tllt Member
    this happened to me the other week for the first time. we were driving and passenger was on slacker looking for songs and it froze and rebooted.
  10. Insight75
    Insight75 Member
    Mount Olive, New Jersey
    This is happening to me quite often. Twice on the way to work. Keeps having issues finding songs (streaming) and then it crashes.
  11. Stasla
    Stasla Member
    New York
    Wanted to share a tip. My X once rebooted itself when parked and wouldn't come back online. Screens stayed black - no response to any action, including the brake pedal.
    This was after the car was sitting in a lot for a couple of hours and I had just gotten back to it to drive away.
    Once I made sure all the doors were closed though it booted back up like a champ.
    TILDR: If your car appears dead (even though it's got enough juice in the battery) close all the doors and try to power it on again.
  12. RDoc
    RDoc S85D
    Boston North Shore
    We've had it happen a couple of times. Weird and scary, but it does seem to be OK.
  13. apacheguy
    apacheguy S Sig #255
    So Cal
    Frequent reboots can be a symptom that the eMMC flash is failing.
  14. wdolson
    Clark Co, WA
    I had a second spontaneous reboot of the center screen in the same place on the road as the first one almost exactly 1 year after the first one.
    I also had both screens lock up when I started the car once. It would move (I backed it out of the garage), but it took a couple of reboots of both before everything went back to normal. Some of the elements of the instrument cluster took the longest to come back like the temperature gauge and the battery charge gauge.
  15. mikevbf
    mikevbf Active Member
    vermont
    My center screen has rebooted about 6 times in the last week, 3 of which were on the way home today. They all happened while streaming music no usb drives in ports.
  16. fabioaqua
    fabioaqua New Member
    Miami
    Then for sure there is something wrong happening with the Streaming. Because my Tesla reboots a lot and the AC turns OFF when I am streaming. Lately the streaming has given me lots of errors loading. Has anyone taken their car in to check the issue of the car Rebooting?
  17. Toppatop55
    Toppatop55 ~Life Is Good~
    Manchester, Connecticut
    I’m having the same rebooting and freezing issues when streaming tunin. The 3g connection is extremely slow and sluggish in my area. Does Tesla offer complementary upgrade to LTE since streaming is the only option for media. Also my MS is still under warranty if that matters
  18. bmah
    bmah Moderator, Model S / Model X Forums
    Lafayette, CA, USA
    If you have a Model S with "only" 3G connectivity, there's a paid upgrade to add LTE capability (somewhere around $500, if I remember right, at least that's what I paid). You can find several threads about it in the Model S (hint hint) forums. To my knowledge all Model Xs produced have LTE capability.
    Bruce.
  19. Stratusbill
    Stratusbill Member
    Scottsdale Arizona
    I’m driving my S from Scottsdale to Boston. It has rebooted several times. Sometimes I’m streaming, sometimes not. I think it’s either Linux or Tesla software that is crashing. But the drive is fine. Superchargers great, plus destination chargers. You can drive anywhere in a Tesla with no worries about electrons.
  20. dark cloud
    dark cloud Member
    BC
    My new to me P85D did it on the first day I brought it home. We were actually parked at the supercharger and streaming music for the previous several hours was fine, but at the supercharger we browsed while streaming and connectivity disconnected and the screen froze. I drove away just to see if it would drive, and that was fine, then a few minutes later it rebooted itself and was fine several minutes later.
    Ironic part was the webpage browsed when it crashed was Tesla's homepage. I am off to investigate the LTE upgrade, as I believe mine is just 3g.
