NMC vs NCMA ? What all else equal difference will it do to a battery being the one or the other?
And what is the e3ld of the two?
Panasonic is NCA. (82kWh)
LG is NMC. The cell used is LG INR M50( or maybe M50-T?), and maybe some chsnge in the chemistry but I serioulsy doubt theres a big difference if any.
LG(and some other as well use the prefix INR for NMC).
There has been information about LG us developing a NMCA which should have a higher energy density than NMC, and lower part of cobalt.
So far, my tip would be that its an old cell, as the energy content in the packs is in pair with or slightly less than the known M50 holds in tests.
A new battery with better energy per volume ratio( = per each cell or per 4416 of them in a M3 LR), should reach a higher capacity in the pack.
The 74.5kWh LG pack used the M48 cells and the 77.8 use the M50 cells(this is stated by Tesla in Teslas certification papers). The numbers ad up quite close with these cells.
SPEC’s:
M48(in 74.5 kWh pack) 17Wh x 4426= 75.0kWh.
M50(in 77.8 kWh pack) 18.2Wh = 80.3kWh)
Real measured capacity:
LG M50 test
17.86wh x 4416= 78.8kWh capacity in a pack.
For the basic question, so we do not loose it again:
In general, seen in tests where panasonic NCA has bern tested togheter with NMC( not necessarily LG Chem NMC), NCA is the best in research when it comes to calendar aging. NMC degrade faster(not by much but faster), specially when the ambient temps is high and SOC is high at the same time.
NMC is better at withstanding big cycles so they probably degrades slower if used with big cycles.
In the end the difference probably is not that big and it will be the usage that set the factors that determin which battery that is the best. Low mileage and left at high SOC in a hot environment: NCA should be slightly better.
If left with low SOC during nights but big cycles like 90 or 100% to 10%, the NMC might have an advantage.
I would be upset if I did get the NMC, or NCA.
As we do not know the exact spec and/or have seen any test of these cells against each other its hard to know exactly. All info from above is in general or Panasonic NCA(in some cases Tesla Model S NCA) against NMC in general.
I have sone Panasonic cells on order for some home tests, and the rumor in battery nerd forums is that these indeed is the same as Tesla cells.
