So everyone saying this is a niche problem limited to sub zero temps is incorrect?
You keep on saying that people are saying that as a blanket statement, but at least I can assure you that that is not what I have suggested, in the messages I have written in reply to your concerns. There are a lot of factors here, and they have to be untangled. We do know that cold weather doesn't help, of course.
All else being equal (including temperatures), the higher voltage limit on the new Performance cells vs. the prior versions of the Performance, under load, is going to limit the power output substantially vs. the prior Performance (because you can draw less current before hitting the limit). That seems clear - there's not really any way around it unless the new cell actually has
lower internal resistance at a given temperature than the prior cell (again...the caveat was "all else being equal")! Anyway, there are a variety of cell-related reasons that this voltage limit may exist - and I think many people have repeatedly stated here that we don't know how this story will play out.
Keep an eye on
@MasterC17's posts as I said - he performance tests the car and has/had a 2018 Performance as well.
Comments on Performance Model 3 Drag Race
It's not also not clear that the voltage restrictions in Europe are the same as in the US. The vehicles for 2021 probably perform the same way, but there's a lack of data from the US at low SoC (perhaps it's around if you search for it - I have no idea). So I would just caution you should be careful about drawing firm conclusions from the European data (even though it's probably fine to do so).
Since you own the car already (I think), I'd just recommend patience and seeing what happens. It's not unusual at all for Tesla to roll out software updates which significantly alter the car's performance, so you can hold out hope for that if you want. If you don't own the car already, and you're not happy with it, don't buy it.
