Tour’s and Elon’s (aka, the Charlatan)!There's robotaxis in my heart. In my heart.
Never seen that ...While waiting to make a right turn, it drives off the road and waits half in the shoulder. Then corrects once the other car moves. Junk.
Never seen that ...
BUT, I've seen a ton of people do that. Sometimes because they are distracted and at other times to be able to see in front of that truck. Just the other day a guy in front of me drove almost a full block like that ...
ps : FSD now goes into the shoulder while turning. A definite change from 69.x
Yeah. On 11.3.3, I was approaching a roundabout, and was interested to see how well it handled it. Well, not well. Approaching the roundabout there is a "suicide lane" for bidirectional left turns in the straight road south of the roundabout. The suicide lane does not itself participate in the roundabout in any way. But just short of entering the roundabout, the car signaled and moved left into the suicide lane. I yanked it back where it belonged and proceeded manually. I'm not sure what would have happened if I'd let it go.Failed worse than ever in two different roundabouts.
Just the one attempt? If duplicatable, I'd love to see that video. It should not move immediately to the left, NOR cutoff an approaching car. Two component fail?Entering the highway, it shot all the way over to the left passing lane, cutting in front of a car that was clearly moving much faster than mine.
Not sure. Was heading down the on ramp and it didn’t signal, so I did. 1000’ later it enters the right lane at the very end of the ramp and then continues another lane to the left (passing lane).Just the one attempt? If duplicatable, I'd love to see that video. It should not move immediately to the left, NOR cutoff an approaching car. Two component fail?
You sure FSD didn't disengage, either silently or due to some wheel torque that was missed due to the more complex traffic scenario? Sounds like what might have happened due to 1) not signaling, 2) multiple lane changes, and 3) cutting off an approaching car.Not sure. Was heading down the on ramp and it didn’t signal, so I did. 1000’ later it enters the right lane at the very end of the ramp and then continues another lane to the left (passing lane).
Not sure. I was focused on cutting off the other car, rather than documenting the occurrence. If I were to guess, I was nearly a 1000’ before entering the highway when I helped it signal. It might have stored and later executed a lane change after entering the highway, rather than using that stored signal to so intentions of entering the highway. Will try to replicate next time I’m heading that way.You sure FSD didn't disengage, either silently or due to some wheel torque that was missed due to the more complex traffic scenario? Sounds like what might have happened due to 1) not signaling, 2) multiple lane changes, and 3) cutting off an approaching car.
Suggestion:24 mile Sunday drive - Highway, residential and rural roads
Conditions: Dry and mostly cloudy
It did just okay, overall. Some issues include:
1. Entering the highway, it shot all the way over to the left passing lane, cutting in front of a car that was clearly moving much faster than mine. Really pissed that other driver off. I waved when he flipped me a middle finger.
2. Still tried to “dive” into the shoulder at that same spot as yesterday (see prior posts), even when no lead car was in front.
3. Very heavy/jerky braking and wheel spasms at numerous turns/intersections
4. Missed its turn at a 4 way stop. Just sat there until all cars were done.
Positives:
1. Cruising on the highway (with minimal lane changes toggled on) was good.
2. Handled a construction and demilitarized zone well. Even went around a downed Hazard barrel and navigated around many that were in a new, “under construction” roundabout. Why it can’t handle old and existing ones remains a mystery.
3. I arrived home in one piece… this time…
Good idea. Let's all do that. I was always on chill for 17 months and changed to assertive a month ago. I like assertive much betterSuggestion:
When posting your FSDb drive observations, share your FSDb profile setting. That might explain a lot, like hesitation when turning, etc., more so than an inherent issue. Mine is set to “Average” and I usually flip the “minimal lane changes” toggle on as well.
Must. Try. Assertive.Good idea. Let's all do that. I was always on chill for 17 months and changed to assertive a month ago. I like assertive much better
If that was your last post, we know how it turned out for you. RIP !Must. Try. Assertive.
This is perhaps the result of a design that uses the same input (driver selects turn signal) for two possible commands (either turn on the turn signals, or command a lane change). If autopilot (or FSD) is engaged, there is no way to "help" the system by compensating for its non-use of turn signals without also commanding a lane change.Not sure. I was focused on cutting off the other car, rather than documenting the occurrence. If I were to guess, I was nearly a 1000’ before entering the highway when I helped it signal. It might have stored and later executed a lane change after entering the highway, rather than using that stored signal to so intentions of entering the highway. Will try to replicate next time I’m heading that way.
