Lido
@LuckyLuke do you have the North America .bin file? I dont see my current nav version and the card appears to be unreadable. car was up to date as of about a month ago so I would assume its the newer version.I have sent you a dm
what sh file are you talking about? original scripts?This is going to sound so horrible but does anyone have a basic instruction set for how to run the .sh file once I have my new sd card and the file in a linux virtual box?
I dont know anything about commands over here lol
To clarify,This is going to sound so horrible but does anyone have a basic instruction set for how to run the .sh file once I have my new sd card and the file in a linux virtual box?
No need for scripts. On a card with a capacity of at least 16 GB, create 2 ext3 partitions. The cards will download by themselves. And this script is executed not on the map, but from within, in the system.To clarify,
I have the SD card mounted in the vbox and the nav-sdcard-format.sh file is in the root of the sd card. I deleted the .txt and changed to allow to e
In the graphical interface of Ubuntu, it is quite enough to select a partition, the advanced settings button - to restore the partition image. In this case, the partition does not need to be renamed or formatted - just create 2 partitions of the required volume of any format (fat, ntfs, ext - it doesn’t matter) - and restore them in the existing way. Which of them is active is registered in the system, it is not necessary to indicate this. If you want to download current maps, then it is better to upload older ones, the system will determine for itself that they need to be updated. Well, or execute "handshake" in the updater@Flaminis
I am using the nav-sdcard-format.sh file
I have the sd card mounted in my vbox to /media/mike/nav/ (nav is the name I gave the card
I created 2 partitions at 7.9gb each and named them NAVDEV and OFFDEV based on what I read in the notes for nav-sdcard-format.sh
I left the car connected to wifi for the last day but still see no changes.
@LuckyLuke was kind enough to provide the NA maps for an MCU 1 car. the file ends in .map should I load that file into the NAVDEV partition of the newly formatted SD card and load again or do I have to try and restore the drive from the new NA maps file the same way I would restore an image using an ISO file?
about mtd7 is not entirely true, often according to the logs mtd9/10 fails according to which of the mmcblk0 partitions is active, to restore working capacity it is quite enough to change only it. ENV touching once again can be fraught))If you have a black screen because of the nav card failing and the Tegra is stuck in recovery mode then only swapping the MicroSD will not result in a working MCU. You would need to have the Tegra fixed (nor mtd7 corrected). If still needed DM me I can help you with this.
Removed the MCU and send into service to check all possible things.
Both eMMC chips, filesystems and NOR chip are in good condition. Done backups. One filesystem corruption was repaired. The MCU still remains black screen.
There is no microSD card in the slot.
Sure it is availible for upgrade, but first at least two month wait time from now. Second, it is not cheap. Third, as it's a 75D, we have only a few SuC around so longer trips are still a pain, many places reachable only with 50kW CCS (it comes out 40kW for this battery voltage). Fourth, cybertruck is ordered so lets wait some time, it will show if i decide to change it to MCU2 or switch to an MS100D for example.Just a curiosity. The mcu-2 system is so vastly superior to the MCU-1 I don't know why people don't just pay the $1,500 to $2,500 to get it done. Is it not available in Poland and other European countries?
Like I say, just curious. To each his own.
In that case the easiest solution is to put a MicroSD card in the slot and edit the symlink on the filesystem to point to the SD instead of MMC, therby omitting the onboard EMMC.
The glove box issue is for sure the connector of the button or opener is not in place - thay need to be removed for access mcu.This is crazy because 2 weeks ago i got my nav card replaced. This issue started showing up right after! A mobile tech is comming to check it out for free and hopefjlly fix it. My glove box also does not open now after i got my car back for this service...
Will they give me a new mcu free?
Either way im going to save this thread so i can show the mobile tech guy
Thanks
