In fact, you can now only manage drivers in the app. The section in the website to manage drivers has been replaced with a message telling you to use the app.You can now manage drivers in the app:
good shout!In fact, you can now only manage drivers in the app. The section in the website to manage drivers has been replaced with a message telling you to use the app.
Interesting… Mine is showing KWH instead of miles and it is stating 0, despite the fact it charged and my charger app confirms this.added charge in km also fixed
I don't have that option, I presume it's because mine is a lease?In fact, you can now only manage drivers in the app. The section in the website to manage drivers has been replaced with a message telling you to use the app.
Correct, you will already in effect be an “additional” driver as the lease company hold the “master”I presume it's because mine is a lease?
Try buying a jar of jam. Then look at the label and see that it is 454 grams.Milk is still sold in pints ... litres too, but mostly pints. (The fact that we barely notice shows how much difference it makes!) There was a huge kerfuffle when metric was coming in and we were in the EC and would potentially not be able to buy a pint of milk or a pint of beer ... it was the Brexit thing before Brexit was even invented ... so there was some kind of deal that allowed certain items to be sold in their old imperial quantities... and that's continued to this day. I'm not sure if there was anything other than milk and beer as the exceptions.
Why 454 grams? Because that is 1 pound!
Same for sausages.Try buying a jar of jam. Then look at the label and see that it is 454 grams.
And this is a few hours later...I swear the HVAC button in the app looks different every time I look at it!
Sometimes there is like a halo around it and it seems to be glowing although it is actually off.
What does that mean?
I think I get it after driving in cold weather and the battery is still warm but the car is actually in sleep and no HVAC on? Or doesn't it mean anything?
It's condensation inside the icon. Tesla will say it's "within spec" unless you can actually see water accumulating in the HVAC iconI swear the HVAC button in the app looks different every time I look at it!
So it seems now there is more bugs to replace the old ones, namely:
- Change the Battery between % and Ranges, kill and reopen the app and it has reset
- Notification for Charge start not active despite being enabled.
- Set charge limit to a percentage and it cuts out 1% less than this (unsure if this is actual or a % discrepancy in the app)
I experienced the latter last night, set my charge to 80% as normal - scheduled charge between 00:30 and 04:30 and woke up to "Charging completed at 01:54 with battery at 79%" (despite the fact that the charge window was still active and the slider was set to 80%)
Very bizarre - a lot of these were working fine and then just randomly started happening after a couple of weeks :/Apart from your last "issue", which I cannot comment on as I just charge to 100%, I haven't experienced any of those problems with the new app?
It does in the widget. But in the app you can change % and miles just like in car display.I was under the impression that the app always defaults to the same unit of charge (% or miles) as is currently selected in the UI in the car.
