This thread is for the rear wheel area, but I think people have mentioned issues at the front.
Anyway, made a video, and it really seems like this is coming from the inner CV joint, or perhaps the motor unit itself, in my case. Hopefully the video works. Obviously this is from the FRONT axle. To be clear, the other wheel on the front axle is on the ground. So the motor is spinning. But it's an induction motor.
You can see with the rotor in particular, that some momentum develops, and after it stops turning, something else stops turning a while later (you'll see my hand jump as it hits). So there's definitely quite a lot of play here - a couple degrees for sure. In the slow motion you can see the jump as well. Not really visible when looking at the inner CV joint, but that's where the noise appeared to be coming from.
Slow motion goes for a while - you can always skip to about 1:12 for the inner CV clip.
Is this noise similar to what other people have been hearing? Obviously I'll have the service center take a look at some point in the indeterminate future when I am forced to bring it in.
tapping_axle by
AlanSubie4Life
