AlanSubie4Life
Efficiency Obsessed Member
@Saghost Thanks for the old screen capture.
Did some reading...IGBT is the tried and true power switching technology but modern Silicon Carbide Power FETs probably win out, the more power being switched. The SiC devices perform very well at high temperature due to wide bandgap and can have very low on resistance and high breakdown voltages. So, for extremely high power, SiC is good.
Elon did say that the front drive unit is Silicon Carbide as well, and see earlier in this thread for front drive unit identified as “IGBT-HC” (high conductivity???) and I don’t know how SiC IGBTs compare to SiC MOSFETs. But anyway...
Regarding which drive units belong to which Model 3 models:
1) Well, since the third one (part number ending 990) says “AWD” right in the description, I guess it is safe to say that is used in the AWD versions of the car. Presumably both Performance and non. Unless there is a fourth part number they have not yet provided!
2) MOSFET-LC most probably means low gate charge for the power FETs? For power MOSFETs this is a “thing” - allows the devices to be switched faster and more efficiently (less switching losses). There are a host of different parameters for power MOSFETs, so maybe the power FETs are different for this motor, and thus they may be superior in other ways as well (lower Ron, lower switched capacitances on the drain, etc.)
So my best guess is:
70 motor/DU -> SR/MR RWD. (IGBT)
80 motor/DU -> LR RWD. (MOSFET)
90 motor/DU -> all AWD (MOSFET-LC)
AND perhaps these parts all have the same actual motor (simpler?), but the drive electronics (and therefore their maximum capabilities & cost) are definitely different, based on the description.
