Maybe you are correct, the efficiency gain is from lowered ride height.
View attachment 496253 Haven’t seen too many SR+ reporting in...
08/2019 build date.
1120980-00-F
P1085693-00-F
Can we get a summary of the different motors? There’s so much detail in this thread I’m already mixed up on the difference between 990, 989, etc! I have a May 2019 SR+ by the way.
Edit: from what I can gather, the 980 motor is used on RWD and P configurations and has a higher output compared to the 990 motor used on the AWD configurations. There are various revisions of each with no identifiable difference.
Has it been ruled out that the 990 (MOSFET-LC) is not just a binned lower capacity version of the 980 (MOSFET) drive unit?Edit is right.
990 is used (based on currently known info) only in the LR AWD non-P, and only since sometime early 2019 (with some 980s showing up as late as I think April or June maybe?)
980 is used in the P and all RWD versions of the car.
Based on this info we can conclude:
the 990 is cheaper, less efficient, and less capable of the max power output when compared to the 980.
Because if it wasn't cheaper- there'd be no reason for it to be used in anything- they certainly wouldn't use a same/higher cost motor especially a less efficient one.
And If it was cheaper but equally or MORE capable, they'd use it in everything.
Sorry for the noob question but how do you get this view? Under the car?View attachment 496253 Haven’t seen too many SR+ reporting in...
08/2019 build date.
1120980-00-F
P1085693-00-F
It is right behind the driver side rear wheel.Sorry for the noob question but how do you get this view? Under the car?
If that were the case, costs would be identical. No one knows unless a full tear down takes place between both motors.Has it been ruled out that the 990 (MOSFET-LC) is not just a binned lower capacity version of the 980 (MOSFET) drive unit?
I’ve been in manufacturing where lower performing parts were given a different part number but cost the same to produce.
But we know that's wrong.
Because the 990 is less efficient than the 980, all else being equal but the motor.
If they're the same motor, but "binned" for the capable-of-more-power ones being stamped 980, that would not be the case.
Further, if this was NOT a physically different motor, just the result of the magical no-evidence-for-it-ever-happening-ever "binning"- why did it take them like a year and half from first production to start actually doing it?
A delay in implementing binning does not mean they do not bin. Nor does the delay in differentiated part numbering prove they were not tracking sone other way (what were the blank motors?)
The fact ordering a replacement 980 doesn't require a VIN tells us that.
Got a P with a "magic super special" 980? Got an AWD with a "regular" 980? Tesla doesn't care.
Everybody gets the same 980 replacement. They don't even want to know what you had originally. And that was true before the 990 was even in the catalog.
If there really were super special 980s that'd not be the case.
Edit is right.
Is there any hard data like a tear down showing they use less MOSFETs in the 990 to indicate they are not binning?
Huh? Isn't 980 the better motor of the two? As such, of course you would replace a 980 with a 980.
Yes. A 980. Not a special magic binned one.
This disproves the idea there was any "binning" before hand.
A 980 was a 980.
There wasn't some magical "special" 980 the P got and the rest got the rejects...which was the theory- that you yourself just suggested again- where there was some secret hidden "other" way they tracked which the "special" 980s were to insure that went into a P.
Because if there were then ordering a replacement would require a VIN, for them to see if you need the "special" P version or not.
And that was never true- even when the 980 was the only PN orderable for a rear motor.
(it would also make the idea the 990 is a binned 980 even dumber because it would mean Tesla had a special secret totally hidden binning method using JUST one PN that somehow worked fine... and then after 18 months of production decided to abandon that and use a second PN for the same process for no apparent reason)
