alevek
I have a new replacement cord, just haven't installed it yet. I'll try the contact cleaner.
I used my multimeter to test the cord and I was able to get continuity for all but one of the pins. But, I know there's a circuit board in the handle that sends the charge door open signal, I didn't expect it to be so straight forward.
Would you be able to test / ohm out your charger cable to see if I should have continuity on all pins?
There will not be continuity on all pins. Looking at the plug and going clockwise from top left connector, you will have continuity as follows:
High power black
High power red
Small purple (pilot signal)
Yellow/green ground
No continuity. This pin is connected inside the handle to a microswitch and a resistor network. Resistance between this pin and ground should be 150 ohms with switch not depressed and about 350 ohms with switch depressed. This is what failed on my plug, however this will not impact HPWC self test.
The other small yellow wire in the cable will not show continuty to any of the plug pins. It probably supplies power to the charge port opening transmitter in the handle.
