Hi Everyone,
One thing we wanted to share with you all that will help significantly improve the pedal feel. This free mod won't make the brakes last any longer, but at least they will feel a bit better, and you'll waste less of that critical pedal travel should you ever get into a situation where you need more travel (boiling fluid for example).
The front calipers have heavy pad return springs, and these springs are designed to help improve range and efficiency. However if it's ruining your enjoyment of your car, you'll most likely want to get rid of them. They just pop in so you can remove them and re-install them in the future without causing any damage.
Here's a video showing just how much they retract the pad. You can see the pad is significantly removed from the rotor, and if you don't know much about brakes let me tell you that a small amount of gap like that takes a lot of pedal travel to make up - that's how leverage works!
With the clips removed this retraction is no longer visible.
Pads are 100% the first thing to do, and should really be done at the same time as rotors. Rotors remove heat, but high-performance pads can run at a temperature that is in excess of double the OEM pad temperature. No upgraded rotor can compete with that, it's just thermodynamics!
