lbowroom
Plaid, white on black, CF, 8/27/21, Track Pack
Well now I feel dumb, I'm only half doneThere are four total - two per caliper. Just to confirm since the picture only showed two brackets!
Will this mod reduce range?There are four total - two per caliper. Just to confirm since the picture only showed two brackets!
Hi Everyone,
We opted to go for the 400mm rather than 380mm because it will be very rare for anyone to use 19" wheels who are serious about performance, and for the tiny additional cost, it makes more sense to fit the largest rotor possible as we're talking about a 1000hp vehicle here! We'd also like to add additional thickness to the disc but need to be careful as the caliper wasn't designed for a wide rotor and some rubbing after thermal expansion could be possible if we push our luck too much.
No I didn’t! Don’t want the pads to rattle around in there.Did you take it off?
Did it make a difference?
Ok, weird result. Sounds like a box of rocks when I’m free wheeling. Could it be the seals haven’t let the pistons advance and the pads are rattling in the free space?
That’s what I just said! Pad rattleOk, weird result. Sounds like a box of rocks when I’m free wheeling. Could it be the seals haven’t let the pistons advance and the pads are rattling in the free space?
Must have missed that.That’s what I just said! Pad rattle
I'm thinking of trying out some new brake pads from EBC or Racing Brake in the interim... if that doesnt help, then I'll think of a brake kit...
Did it gives them a more firm feel?Must have missed that.
Had to pull the wheels to get the clips back in the proper position. Back to silence. Didn’t sound just like rattle, sounded like pebbles intermittently making contact. Anyways, All good now.
Please share your resultsI'm thinking of trying out some new brake pads from EBC or Racing Brake in the interim... if that doesnt help, then I'll think of a brake kit...
I seemed to have stepped in something and can not get it off the bottom of my shoe.I am pretty sure you just made all this up!!
Right, so to eliminate the pad rattle some different clips will need to be made which push the pads down, but not away from the rotor.
Pad rattle is certainly annoying!
Many of us agree with you 100%. I will let everyone know by Thanksgiving holiday weekend what the difference is with the RB drilled/slotted brake rotor/pad kit. btw - I'm in your area.I live off a highway where 150mph runs can be done over and over easily and from my experience with many runs under my belt on this car, the stock brake pads and rotors and pressure feel is terrible.. I can over heat and fade them easily after 1 hard stop from 140.. and on regular streets I need 2x the stopping distance for quick pulls to 60..
The thing is, the brakes are actually strong.. its the crap rotors which over heat and the pad material is very soft and does not withstand a high temp at all combined with regular brake fluid which quickly boils.. its a terrible combo.. Also ill mention that since im doing high speed stops... im usually already coasting at a high rate of speed, so there isnt any pre-heating of the brake from accelerations..
Upgraded rotors, some stainless lines, some castrol srf brake fluid and proper high temp pads will make this car stop great..
So the true answer.. yes the brakes are good and strong.. no they do not hold up at all for the 4800 lbs and 1000hp this car is.
Most daily drivers of the car wont care or have an issue.. but if your drive hard, do a lot of high speed runs or any tracking you will def want to upgrade..
I find most factory brakes on cars are good enough once a proper pad, and fluid is installed...and yes in stock form they are about as bad as a Toyota Camry
In comparison, I drove a Model 3 Dual Motor locked in normal mode and beat the crap out of it for a month.. the Oem brakes were "Excellent" in comparison to this Plaid. Tight, great pedal feel and stopped on a dime.. The Plaid feels like I have the brakes of a school bus pedal basically to the floor before any real pressure is felt and then they melt almost instantly under duress... I brake significantly earlier than I need too and have been very gentle on the brakes until upgrades come out..
* 15 years track experience + instructor status, extreme canyon racing, 36 cars and countless custom brake kit setups is my background...
U doing them yourself? If so, we can do them at the hangar if you want.Many of us agree with you 100%. I will let everyone know by Thanksgiving holiday weekend what the difference is with the RB drilled/slotted brake rotor/pad kit. btw - I'm in your area.
