JRP3
Hyperactive Member
I'd be surprised of any type of balancing was taking place at lower SOC's, and most balancers that I'm aware of do most of their work near the end of charge.
I'm not sure by what mechanism "passive" balancing would occur.
The biggest problem I see with all the kind suggestions by Forum members to Range charge repeatedly and then discharge the battery to minimum is that it is completely contrary to what it says in Tesla's manuals. If a Service Center tells me in writing on a Repair Order to follow that procedure, I would gladly do it. I have been following Tesla's instructions to charge the battery daily between 60%-70% and keep Range Charging to a minimum.
What you are describing could only happen when a cell is full or nearly so. Say you have two cells, one is at 3.44V and the other is at 3.50V. Assuming similar effective internal resistance* both cells will keep accepting charge at the same rate. Now at higher voltage/SOC if one of them is nearly full then it may start to shed excess charge as heat due to an increase in effective internal resistance. However you don't really want that to happen, you want an external balancer to start dumping some charge either through a resistor or by shuttling it to a lower cell. Complicating this is the effective internal resistance of one cell could be higher than another and that cell may show a higher voltage when charging even though it's not actually at a higher SOC. Lower charge currents help avoid that, and ideally measurements would be taken after the charging has stopped at resting voltages, which eliminates the internal resistance issue.My understanding, and it could be bad since it's based on what I've read rather than personal expertise, is that during a slow charge the SOC tends to level out between the cells because the cells with the highest SOC tend to take a bit less over a given time period. That doesn't happen during a rapid charge. Of course, there are the questions of "what constitutes slowly" and "is there enough variance in the individual cell's rate of charge in this situation to make a significant difference".
*I'm using the term "effective internal resistance" because it's not really resistance but diffusion rates of ions through the SEI layer and into the structure of the electrode.
In regards to the klunking sound from the motor I described earlier.
The service center checked all suspension points and retorqued them. They also checked the motor mounts and they are fine too. The determined that the sound is coming from within the motor.
They let me take our car home and they will be bringing us a s60 loaner next week so they can do a drivetrain diagnostics with the engineering team from CA. I was told that they may end up replacing the drive train.
They would have kept it today but they only have s60 loaners and I need an 85 to get home. (I was puzzled by the s60 loaners, I thought they were only doing p85+ loaners, perhaps they are trade ins from people buying the p85+'s?) I will let you know what the issue is once they find it.
Updated: oh yea, they told me they didn't notice it with creep turned on. Since we have always driven stick, we keep creep turned off. I think the creep function hides it by always having torque on the motor.
Good they covered it. How much does out windshield cost if anyone knows?
So the SC determined that my charge port is bad and that in turn fubarred both my and my neighbor's UMCs. They are replacing the charge port and giving us each new UMCs.
