InTheShadows
Has anyone noticed a klunking sound from the motor area when at low speed, like in a parking lot when you press lightly on the accelerator? The sound reminds me of a sloppy universal joint on the driveshaft of an ICE.
Anyone know what this is: About one time in ten when I'm getting out of the car, it will start to "chime" in sets of three "bongs" for maybe 30 seconds. This isn't the rapid three bongs you get when an alert comes up on the dash, but slower and makes me think of a key-in-ignition or headlights on reminder. There's no message of any sort on the screen, and it does stop on it's own. I'm curious to know what the car is trying to tell me.
I am experiencing that sound. TC has a part on order to repair it. A motor mount I believe.
In a few different threads it's been surmised this is accidental touching of the brake pedal when getting in tothe car and thus the door is still open.
I believe that's been narrowed down to the FOB in your pocket being "clicked" to lock by accident .... with the door open.
I have a P85 VIN:1586 bought in 11/2012. I have close to 16K miles on the car. I live in the Bay Area where the temp today is approximately 70. Last night I did a range charge for only the 4th time since owning the car and I was shocked to see that the Rated Miles on a full charge are only 246. I never let the battery get down below 100- 140 miles. I only used the Superchargers on the way back from LA last year on I-5 because the ones on 101 were not active at the time. When I Supercharged on that trip, I only charged to 90% or less. My car is usually charged to 170-180 miles for daily use. My 90% Rated charge is down to 212. I have been doing all the right things espoused by Tesla - like leaving the car plugged in most of the time so I am very disappointed to see the loss in range. My life time Wh per mile is 316.
I feel this is unacceptable. I have taken care of the car and bought 8 year extended warranty and maintenance plans, had the car serviced on time. I don't hod rod or race the car because I have a bad back and have had neck surgery. I think it is time to get in touch with the higher ups in Tesla and find out what the hell is going on here. This is very upsetting to say the least.
You car and battery are very likely fine, don't worry about it.My car is usually charged to 170-180 miles for daily use.
Cars charged to less than 90% regularly and rarely range-charged are more likely to drift out of balance as it's harder to balance a pack when it's not near full or full.
I'm not sure there is any good reason to drive it to or near to 0 to balance the pack. Lithium has no memory effect and the balancing takes place near the end of charge, assuming they are top balancing the cells. Leaving it plugged in for extended periods after range charging should do the trick.
