Hey all, so I have been looking for a good deal on a S100D and after looking at new Tesla inventory for a the past couple of months I realize I have passed up some really good buys just because I want the Sub Zero package and I have yet to find a less expensive S100D with all the other options I wanted and Sub Zero.
I only think I'll "need" the steering wheel heat 10-15 times a year to maximize range on long cold and/or snowy trips. So with this in mind, I've found some aftermarket options that might solve my problem and wondering if anyone sees any reason why these wouldn't work well in an S100D?
The first, cheapest, and least invasive rear seat heat option is the heated seat cushions that would just go on top of the rear seats when needed and plug into the 12 volt, 12 amp Aux outlet via a splitter. The max total draw(for both of these) would be 10A on high, 6A on low.
http://a.co/1Eugkw7
The second, more permanent option are these built in aftermarket heating elements. They would require hard wiring a couple of seat heat switches into the 12V system. Is this possible and if so what are the current limitations?
http://a.co/3SHSYYs
Here's a steering wheel cover that draws 2 amps. Anyone have any experience with this? The other option might be heated motorcycle gloves or just regular gloves if they work.
http://a.co/1w3gkM4
I realize that the route of adding aftermarket/non-Tesla seat and steering wheel heat may seem a bit unorthodoxed to some of you, but if it saves me $5k - $10k I'm good with it!
http://a.co/1Eugkw7
http://a.co/3SHSYYs
http://a.co/1w3gkM4
