I am just over 100k miles with pretty much the same 90% rangeJust hit 100,000 miles this week. 90% is 211.
My April 2016 P90DL MX is also at 199 miles at 90% charge with 80k miles on the odometer. But it was never more than 230 miles at 100% when new (so I’m thinking it’s had 5% decrease). Are you sure about the 250 miles range when new?My 2016 P90D with about 75k miles 90% is at 199 miles. Seems to be over 10% loss if I back calculate the full range at 250 miles.
Is this enough to request a replacement?
Edit: read back some pages and I guess they don’t cover it for older cars.
I’m not sure where DOE/EPA got their range estimates, but my MX maxed out at 230 miles when I took delivery. Mind you, there were improvements in battery management and motor efficiencies, so it wouldn’t surprise me that MXs built later in 2016 had more range.The Performance was 250 miles to the 257 for the non-Performance, see for yourself at Compare Side-by-Side
So yep, looks like about 10% down. Unfortunately worse than typical but not bad enough to covered under the battery warranty.
So you have had only about a 4% degradation. That is very good. My November 2016 X90D has lost about 10%. It's 90% used to be about 232 and is now about 209. My guess is that my degradation is about average for a 2016 X90DI’m not sure where DOE/EPA got their range estimates, but my MX maxed out at 230 miles when I took delivery. Mind you, there were improvements in battery management and motor efficiencies, so it wouldn’t surprise me that MXs built later in 2016 had more range.
Our BTX5 Raven has degraded about 10% as well.So you have had only about a 4% degradation. That is very good. My November 2016 X90D has lost about 10%. It's 90% used to be about 232 and is now about 209. My guess is that my degradation is about average for a 2016 X90D
Those numbers were supplied by Tesla. There's 2015-era reporting about them surfacing before the Model X came out. It's entirely possible that the actual efficiency came out lower at launch than originally projected and Tesla never revised things. However I doubt it as the Design Studio also showed the same 250 mile number in 2016. Model X Design Studio | TeslaI’m not sure where DOE/EPA got their range estimates, but my MX maxed out at 230 miles when I took delivery. Mind you, there were improvements in battery management and motor efficiencies, so it wouldn’t surprise me that MXs built later in 2016 had more range.
The P90D pulls a much higher amperage out of the battery, plus the pedal curve is much steeper, hence nimble spirited driving feeling.I'm not sure I'm agreeing with where this discussion is going.
According to the first post in this legendary TMC thread, Both the 90D and the P90D (at least prior to the mid-2019 refresh) came with identical battery packs. The nameplate capacity was “90 kWh”, and they actually only held 81.8, but hey who’s counting. Either way, they were the same pack.
Now I guess what people are claiming in the last few posts is that a) the P90D has a higher consumption rate than the 90D and b) this will result in a higher number of charge cycles all other things being equal and c) this number of charge cycles, as much or more than calendar age, is the main determinant of battery degradation.
Do I have this right? I mean, I actually agree with those things.
Because if that's all true, then it matters how many more charge cycles we are talking about. That same post cited above gives an idea of the relative difference in consumption a person might expect between these two variants: the regular non-performance 90 had a “rated” consumption of 320 Wh/mi and the Performance version used 333 Wh/mi.
Obviously everyone’s *actual* usage will be different, but this ratio should give a decent guide to how many more charge cycles one version might go through vs the other version, all other things being equal.
It’s a 4% difference, people.
Show me a chart of degradation , not versus time , but versus charge cycles. (Someone has helpfully supplied exactly such a chart just a couple posts above this one.) Pick a data point. Make a note of how far you are to the right along the X axis. Now, move your ruler FOUR PERCENT FURTHER TO THE RIGHT and tell me what point lies directly above this new location. They’re almost identical values. Maybe a fraction of a percent different.
I'm sorry but that comes nowhere near explaining how one guy has 256 and the other guy has 226, even if one is a 90D and the other is a P90D
Am I missing something?
Thanks!Congrats on your BMS completing battery balancing, did you run it all the way down too?
I generally like the angle of this advice, particularly if someone regularly spends time with the pack between 80-30% for long calendar life. I want to add some background and nuance.That might be enough to keep your BMS mostly accurate, but you gotta expect such fluctuations as the pack ages, usually pronounced for the first few years. If you have an extreme range drop usually you can get that range back by driving to zero and charging to 100%. Don't LEAVE it at 100% for more than several hours (like before a trip or at a charge stop where you are eating is OK), drive off the top 10% before you park it. If you have to park it turn on Sentry mode until you get it down below 80 or 90%. Also, don't be afraid to drive to zero if you are near your charger, there are a few miles below zero to get you home.
That said when your battery starts to get real old you'll start to see sudden drops while driving (I had 11% but it jumped to 2%), when you start to experience these issues you can be a little afraid of driving to zero.
