I've probably supercharged 80% to 85% of the time - Just exported an excel of my charging history and I have over 900 rows of entries.14% degradation is pretty gnarly.
Keep pressing it and escalate.My mx p90d is at 165 miles at 80%. Everytime I ask them to look at it before the warranty expires they say every is fine
What is your claim? The warranty you received doesn't cover degradation. It only covers failures. Does your car still charge and drive? Then the battery is fine as far as the warranty goes.My mx p90d is at 165 miles at 80%. Everytime I ask them to look at it before the warranty expires they say every is fine
Every few months I try to charge to 100. It's 204 at 100. Sometimes I'll set it 100 and it will stop charging at 95Even under the current degradation warranty that wouldn't be covered. It's about 82% of original. I get that it sucks, but likely they won't do anything.
Just confirming: you do charge to more than 80% from time to time, right? This isn't just an out-of-balance pack?
Incorrect. It does not only cover failures. It covers "repair or replacement of any malfunctioning or defective batteries."What is your claim? The warranty you received doesn't cover degradation. It only covers failures. Does your car still charge and drive? Then the battery is fine as far as the warranty goes.
But a battery that has degraded (which is every single one ever made), and still charges and powers the car to drive, has neither malfunctioned or is defective. It is operating as designed.Incorrect. It does not only cover failures. It covers "repair or replacement of any malfunctioning or defective batteries."
And that source isn't actually the legal warranty document. The actual document has actual verbiage about not covering degradation.
The Battery, like all lithium-ion batteries, will experience gradual energy or power loss with time and use. Loss of Battery energy or power over time or due to or resulting from Battery usage, is NOT covered under this Battery and Drive Unit Limited Warranty. See your owner documentation for important information on how to maximize the life and capacity of the Battery.
I don't agree with your bias, and how much it has malfunctioned vs. being designed to degrade is clearly a gray area that their lawyers decided they needed to define better. So in your opinion, even if it eventually degrades to 0, that's fine? In my mind that would be both a malfunction and defective - but to you it's designed that way. Ok, let's save it for a judge to see.But a battery that has degraded (which is every single one ever made), and still charges and powers the car to drive, has neither malfunctioned or is defective. It is operating as designed.
100% agreed.Maybe being a little stubborn here? If a company makes statements publicly available, they are responsible for them. Also, they always push that you'd be able to travel long distances in the model s. If you can't make it even from supercharger to the supercharger, you can't do that, hence the vehicle is no longer able to perform the functions for which it was designed.
No. At that point the battery neither charges, or provides power to drive your car. It is no longer storing, and delivering, energy. It has failed.So in your opinion, even if it eventually degrades to 0, that's fine?
ouch. Are these problems prevalent in 75 also or just 90 like OP?I'm currently on a road trip, and the combination of LONG distances between some superchargers (120+ miles) and severe headwinds, added to the supposedly only 11% decline in the original 90 battery in my X... Meant that I did NOT have enough power to reach one charger. The X did not "limit the power" beyond the usual yellow dots on the energy circle, and surprisingly when it got to zero, that was definitely the bottom. It shut down less than 1 mile later - and just about 1.5 short of the damn charger.
As an added bonus, it has twice now refused to charge above 95% when connected to a destination charger overnight - stopping at 95% both times. It was still drawing power on the screen but not charging. If I unplugged and reconnected, it would SAY it was charging, but at such a reduced level (3kw-5kw) as to not even be noticeable and would have added HOURS to the time there. I don't know what is going on, but it is getting VERY frustrating.
