ElectricAnt54
Also update the spreadsheet pined to this forum.We are a Jan 18 - Feb 20 delivery of MYP in KY. Will post once we get VIN
I heard the same thing. I'm in Colorado so it will probably be from Fremont. I just hope that they don't have 4860 only out of austin and fremont is still on the older battery.Elon said back several months ago that the Austin MY's would be for the Eastern US while Fremont would continue to supply the Western US.
My guess is TX customers (West TX ?) will get Austin built MYs, once they are available.Trick question, which Model Y's does Texas receive, Freemont or do they export the Austin built ones to a border state and then reimport? I wonder what logistically makes more sense.
I'm wondering the same thing since I'm in San Antonio.Trick question, which Model Y's does Texas receive, Freemont or do they export the Austin built ones to a border state and then reimport? I wonder what logistically makes more sense.
From all my have heard. We are not close to AMD in the US, 4680 should start later in ‘22. But we should see the single front and rear castingsGood stuff! It will be very interesting to see what upgrades they kick out at start of production (AMD, structural battery pack, 4680, etc). My guess is they will start with MYP since it’s lower volume and higher in the line. I’m also curious if the presumably lighter weight and potentially higher power output will put acceleration close to the M3P, or if Tesla will keep the MYP close to where it is now.
Time will tell!
Tesla quietly started using 82kWh instead of 75kWh batteries in Ys earlier this year, so there is a precedent. That being said it seems the cleanest way to produce Ys with two different specs would be to start with MYPs (lower volume, higher line) in Austin with the new spec, while producing MYLR at Fremont with the current spec. When Austin can handle increased capacity, they start making MYLR with the new spec, at which point Fremont transitions to the new spec as well. Either way, at some point there will likely be some bleedover. Obviously, this is all speculation.Is there a way to tell what pack is installed by looking at the vehicle's firmware or another way? It would be pretty crappy if they cut into one production line before the other if a customer isn't able to control/pick which they get. If Austin publicly acknowledges the new pack, but Fremont isn't including them, doesn't that severely devalue the Fremont VIN before it's even delivered? So they need to slowly/quietly introduce them to cut both over at the same time. Elon isn't quiet, so don't really think they'll go that route... and they don't seem capable of caring less about the customer experience either... so
Interesting, thx for the reply.Tesla quietly started using 82kWh instead of 75kWh batteries in Ys earlier this year, so there is a precedent. That being said it seems the cleanest way to produce Ys with two different specs would be to start with MYPs (lower volume, higher line) in Austin with the new spec, while producing MYLR at Fremont with the current spec. When Austin can handle increased capacity, they start making MYLR with the new spec, at which point Fremont transitions to the new spec as well. Either way, at some point there will likely be some bleedover. Obviously, this is all speculation.
There may not be a significant difference with the first changes. It might feel like a minor incremental thing. Much would depend on the casting situation, whether the pack has the new batteries or is in the temporary holding mode using the old ones.... then what Tesla decides to do to take advantage of the newer batteries on the scale ranging from more range same weight to less weight same range. Hard to imagine they will change all this at once.Is there a way to tell what pack is installed by looking at the vehicle's firmware or another way? It would be pretty crappy if they cut into one production line before the other if a customer isn't able to control/pick which they get. If Austin publicly acknowledges the new pack, but Fremont isn't including them, doesn't that severely devalue the Fremont VIN before it's even delivered? So they need to slowly/quietly introduce them to cut both over at the same time. Elon isn't quiet, so don't really think they'll go that route... and they don't seem capable of caring less about the customer experience either... so
From what I read somewhere, that is the plan. Ship from Austin to Fremont, until Fremont can make their ownIt's my understanding that the front and rear giga-castings that will be used for all MYs from Austin are designed to use the structural battery pack. However, the current design (i.e., from Fremont) does not work with the structural battery packs. As I recall Elon or some other Tesla exec. has said (probably in Oct.) they have a work around for the Austin MYs in the event the 4680 batteries aren't ready for when production begins. I wonder if the Austin gigafactory could produce enough giga-castings both for their own needs as well as for Fremont for an interim/transition period while Fremont is upgrading their own factory to produce their own giga-castings. In any case the Fremont assembly line would need changes to use the giga-castings, so there would be some down time needed to retool/retrain. If this is possible then perhaps for an interim period Austin could be supplying the castings for both assembly plants while the Fremont Kato Rd. battery factory might be able to supply the 4680 cells and structural battery packs to both assembly plants. Of course, this is just speculation for how Fremont and Austin might be able to produce more similar versions of the MYs during the transition period.
From what I understand, at the start Austin will be making the castings for Fremont. Assume this is so Fremont can limit downtime. Guess once that starts, they can remove old presses and install new.That means the Fremont factory will need to retool now to get the new MYs same as from Austin, any news on the Fremont shutdowns?
