No, I got 80.3kW usable energy from the average Wh/mi multiplied by the remaining range and scaled to 100% battery.Did you checked that via ODB?
Indeed. It's well established that the M3P overshoots the official power rating of 377kW, from around 50% charge upwards according to the 3L max discharge power graph you shared.It's not that simple. The M3P ist overshooting these values since late 2019. Have a look here:
[Wiki] Model 3 / Model Y - Technische Veränderungen
Motoren / Drive Unit / Technical Data Model 3 Performance 2022 - E5LD - LG Chem 5L 79kWH Frontmotor (3D3) Maximum Peak Power: 158kW Heckmotor (3D6) Maximum Peak Power: 235kW Drive Unit Cat 3 Combined Max Power: 393kW Frontmotor (3D3) Maximum Peak Torque: 240Nm Heckmotor...tff-forum.de
Interesting to see the 690Nm maximum torque value (up from 660Nm in the Owner's Manual). That the power controller can supply 840A to the rear motor and 630A to the front. Your conclusion is that "the battery is the limiting factor"?
