Here's a good editorial debunking the nonsense claims of the utilities that solar customers are costing the non-solar customers dollars:
Do solar consumers create a cost-shift to non-solar users?
A case study:
A small business switched to NEM 2.0 through Southern California Edison 12/26/2017. Edison notified the NEM 2.0 customer they would be assigned power plans that best fit their usage. This did not happen, in fact the opposite. They keep the customer in the highest possible tariff in their rulebook that is used to punish those who do not save power.
Before NEM 2.0 in Jan 2017 (same power plan in 2017 and 2018):
$1,003.29 for 5,764 kWh
January 2017 is $0.174 per kWh.
After NEM 2.0 in Jan 2018:
$558.98 for 2,124 kWh for
January 2018 is $0.263 per kWh. This is 51% higher costs per kWh post-solar.
The more solar kWh's that are generated for 2018 increased the cost per kWh geometrically.
Should the test subject increase power output, each kWh is worth $0.075 towards lowering the bill (generation+distribution). Should production exceed consumption, the utility still charges for the customer solar production until the first $230 worth of power is created at $0.025 before the break even point is reached. There is a $230 per month meter charge.
SCE so far refuses to change to the power plan after the first request was made in Dec 2017.
SCE's tariff has placed the current Jan 2018 peak cost for power at 06:00am-06:15am = $175 for 4 kWh used for this 15 minute window.
Out of the $559 billing, $112 of the bill is for actual distribution and generation of the power for January.
Whatever SCE markets to their customers is not actually in their customer's best interests, or even truthful as SCE knows truthful to be.
Bonus point? To plug in a 10 kW EV charger this morning at 6:00am and consume 10 kWh, the bill from SCE climbs $159 x 10kWh + $0.75 of kWh. So $16 per kWh to charge EVs in "Off Peak". Mid-peak and peak rates are signficantly higher.
Southern California is lying to the CPUC and the media, and the public in order to stop EV charging and Solar generation. Make no mistake, this will be a court case later this year that will claim fraud and criminal activities on the part of SCE.
