One correction for
@Derek Kessler : It's a 5-15 adapter.
I would say probably only a few additional ones: 14-30, 10-30, and TT-30.
You quite possibly will want to use a dryer outlet at some point, maybe at family's house, or an AirBNB rental or something. Old dryer outlets (pre-1996 I think) are 10-30, and newer homes have 14-30. And the other is TT-30, which is the travel trailer at some campgrounds and RV parks. A lot of those places have a mix of 14-50 and TT-30 (sometimes both in the same utility post), but some places only have one or the other.
Tesla does sell an official 14-30 adapter, so buy that now. This is pretty important because the Tesla adapters have a resistor built into them which sends a signal to the car telling it what size circuit it's supposed to be and automatically limiting the current without your having to manually adjust anything in the car.
Now, the site evseadapters.com does sell a lot of adapters for Tesla, but they were mostly made back when 14-50 was about the only kind you could get from the Tesla store, so they convert everything to a 14-50 outlet. I do have their adapter pigtails for converting to 10-30 and TT-30, and it's good to have each of those.
But you do have the current limiting thing. You can dial the current in the car down to 24A for a 30A circuit (80% rule), but it's not very good if you forget, which may happen. It's better to have a proper 30A Tesla adapter being converted to a 30A plug type, so the current is already set right. So, it would be good to use the Tesla 14-30 UMC plug, converted to 10-30 or TT-30. There are two ways to do this. You can build your own cables, getting a 14-30 receptacle, and wire, and the other plugs. This isn't too bad, but takes a little time and some basic know-how. Probably the simpler method is the buy the cables from EVSEadapters and just use a Dremmel tool to cut the neutral pin off your Tesla 14-30 plug, so it can fit into the 14-50 outlet that it has. Neutral isn't used on the 240V Tesla adapters anyway.
