The demand savings doesn't make sense as the demand charge is determined by the maximum 15 min load over the entire month. So only throttling some wouldn't change that
Demand charges vary with utility. Mine measures demand over a 30 minute period.
In either case though throttling would limit demand charges. In one case the car could be pulling about 120 kW, in the other it is limited to just 60 kW. The demand is additive, if there are multiple cars charging at the same time overlapping the measuring interval.
Utilities measure the average demand over the demand interval. If a Model S arrives at a Supercharger with a very low state of charge there may be virtually no tappering of the charge rate during the demand measurement interval. Normally that could be at close to 120 kW and it could register very close to the full 120kW demand particularly in the case of a short measurement interval like 15 minutes. On the other hand if that same car were throttled to 60 kW you can see that Tesla would save about 60kW of demand charges if that happend to be the peak for the month.
Larry
