Hi all,
I captured new data yesterday using 2017.32.6 ca28227 on my P90DL with the v2 battery (1071394-00-A). Unfortunately, Tm-spy didn't save anything, but I did have powertools running on my iPad and was able to capture that data.
Max battery was on and ready. I did two 0-60 runs without LM, then two 0-60 runs with LM.
SOC started at 99%, ended 97%.
Good news: there was no difference in peak kW between runs without LM and with LM.
Slightly less good news: best kW during 0-60 runs was 480 kW vs previous best of 488 kW. However, the car did seem to be fighting for traction from a start, which may have limited peak power. I did one rolling start from 30 MPH (without LM) at the end and was able to get
485 kW. So, it could just be traction limited or the fact that my pack has aged in the 10 months since I initially took this data.
You can see in the image below of kW vs MPH that power is mostly back to previous levels.
Last thing I did was make a spreadsheet to estimate 0-60 times from Powertools data:
Dropbox - RunLog 20170904 173920 - clean.xlsx
I fit one line to the first 4 moving data points and another line to the last 4 moving data points. I used 5.9 MPH as the 1 ft speed, taken from the Motortrend P100D article. I assumed the P90D would have similar initial acceleration to the P100D, since it is likely traction limited at that point. I'm also assuming the timestamps from Powertools are fairly accurate. Feel free to use the spreadsheet to do your own analysis.
Results:
It looks like the 0-60 times in the latest release are back to the times that the car was capable of in 2.44.130 before this started.
Without LM: 2.65 and 2.63 seconds
With LM: 2.59 and 2.59 seconds
But, my methods might be flawed since the orange run below with version 17.6.15 gives me a 0-60 time of 2.64 seconds. So, take my 0-60 times with a lot of salt.
