Tam
...maybe 3 inches...
The suspension spec is quoted:
Suspension: 4” in either direction
Still does that mean it can lower to a minimum height of 4" from the ground?
Then again the bed is only 6ft so not much use in hauling sheet goods.
You sure the needed amperage is there?Here's my take. It's an electric pickup with 500+ miles off range. Its got a 240v outlet so I can plug my TIG welders directly into so I've already ordered two of them.
8’ with the tail gate down for easy handling of 4x8 sheets.6.5", same as a F150
You not loading heavy sheet without someone reaching over the side.8’ with the tail gate down for easy handling of 4x8 sheets.
We really need to know the specs of the inverter. If it's 10KW, pure sine wave, I'm in.Here's my take. It's an electric pickup with 500+ miles off range. Its got a 240v outlet so I can plug my TIG welders directly into so I've already ordered two of them.
How do you load long objects like plywood or drywall without sliding them in from the rear amd damaging them? Normally you have a second helper and load it from the side. There's no way to side load anything with the current design.
Also, how do you see out the front? The low slope of the windshield means the A-pillar will be huge/long. I have to imagine that will give very poor visibility out of the front.
Don't forget seating for 6. I take this truck over X anytime! Hate the falcon wings!Its not a toy, its a work vehicle.
I could easliy see Bhp, rio tinto etc buy thousands of these for 'light vehicle' work use.
I would say no it can't go to just 4" from the ground. It will go up and down 4" from the normal ride height. I think they said it had 16" of ground clearance assuming that is at max height that would be 8" when it is at the lowest. And that is 8 inch of ground clearance not the bed height.
I will say that the extended windshield is probably my favorite feature of my Model X. If you’re even moderately tall it’s great to have that visibility rather than the gunslit views from normal vehicles.I load plywood into my truck which has the same size bed everyday. I leave the gate close, lift the plywood onto it from the rear and let it slide in. Sometimes the first be need to be bumped once or twice to get it tight to the cab but all the subsequent ones slide right in. If I am worried about scratches to the plywood I simply throw a piece of carpet over the top of the gate. I can load about 10 sheets of 3/4” plywood in 3 minutes or so and I am old.
I’m not a big fan of windshields with big slants so that will take some getting used to for me.
A large portion of pick up truck owners need a trailer ball in the bed for fifth wheel towing. I do. My horse trailer couldn't be used with this truck, as the sloped sides will hit the front end of the trailer on tight turns.
This pushes me to the Rivian or the new Ford (when it comes out) for my next pick up purchase
Many 5th wheel campers are 8-10k lbs GVW, single axel goose neck horse trailers are in the same range, a bobcat on a gooseneck and many other smaller contractor equipment is also within this weight range. All are regularly pulled with 1/2 ton trucks.I’m curious why are you using a 5th wheel on a 1/2 ton. Everyone I know using a 5th for horses uses a 3/4 at an absolute minimum. I have never seen a 5th wheel on a 1/2 ton. A 2-5/16” ball is good for upto 30k lbs so way beyond what a 1/2 ton can handle.
I’m pretty sure the motors are DC so battery -> motor wouldn’t go through an inverter.We won't know what the inverter can do until it comes out, but the motors draw like 250kW (ludicrous is like 1000AMPS) at 480V. Isn't that like, 500+ AMPS? A nice MIG only needs about 60Amps. Did I do that math right?
That's a somewhat specific use case, I don't think it's a large portion. Most of the guys I know who own trucks just throw *sugar* in the back or go camping. Hell, both of them have camper shells. One does have a Lance on his though.
