Jbapckfan
Ditto for me.Geez, that's not great news. I drive around 150 miles a day and have a MYP coming soon
I drive no where near that but still went with MYLR knowing I can get the acceleration boost. Can you at least charge during the day at work?Geez, that's not great news. I drive around 150 miles a day and have a MYP coming soon
Not really what this number means. The test is done with a continuous discharge so at a minimum you should compare what you get for a single continuous discharge (which is what really matters anyway for range - though not for cost). Of course you will not approach the range - while they routinely get 400+ miles in the EPA cycle, it's done at very low speeds, so at freeway speeds it's going to take a real hit due to quadratically increasing motive force to overcome drag.Both of these might bring me down from the 300+ miles which was stated when I bought the car.
Wonder if that is the case between manufacturers.
In your trip computer, what does it say your watt hours per mile is? For the total time you’ve owned the car.Hi All,
A little context first:
Real life range provided by the energy app vary from (mostly) 160 miles to (rarely) 204 miles after a 90% charge (never did a 100%). So that'd mean a 100%-charged range between 176 and 226 miles, which seems extremely low.
- My MYP is brand new
- I mostly drive it in the city, speeds varying from 15 to 40 with frequent stops
- I don't play Ayrton Senna with my car, don't floor the accelerator (actually I maybe did it twice since I own it, up to 45mph or something)
- Driving mode is set to Sport
- It's summer
Do you think there's a malfunction here? Or is it because of the frequent stops and I should expect a longer range once I hit longer trips on highways? Or something else?
Thanks for your insights!
Jerome.
The car definitely “uses up range” while parked and unplugged, especially when sentry mode is on. If I remember correctly it could be as much as 5% with sentry mode on per day so if charge once a week that would be 35%.I too am getting pretty low mileage on my long range model Y. On an 85% charge, I get barely 200 miles before I'm below 10%.
Range: 192 miles from 85% - 8% = 77%
Extrapolating: 192/.77 = 249 miles on a 100% charge
My driving is mostly local and I do not use sentry mode, but 1) I'm using the a/c; and 2) I only charge once a week so its possible there are large daily battery losses. Both of these might bring me down from the 300+ miles which was stated when I bought the car.
When I charge the car, the estimated range is so far off I don't bother checking it anymore. When I first got the car, I would drive modestly so I could see how close I could get to the estimated range. But I was so far off I gave up and don't check the estimated range anymore.
This is probably my biggest disappointment in the long range Y: the range is not that long.
This could have been Cabin Overheat Protection running; Cabin Overheat Protection can operate when the passenger cabin temperature is above ~90F. This is well below the 105F limit for cabin temperature when Cabin Overheat Protection is On.I don’t use sentry mode.
But I do notice noises (maybe the air conditioner?) coming from the front of the car while it’s just sitting in my driveway. Noises when the car is parked makes no sense, especially since it’s not terribly warm right now. I could see energy being used to cool the batteries down when is 100 degrees, but it’s been in the low 70’s. Maybe my poor range is due to phantom energy loss when the car is idle and unoccupied.
I get like 185 to 240 Wh/mile around town without AC and about 244 Wh/mile at 70 mph highway without AC and like 280 Wh/mile at 80 mph.. My average consumption for 10000 miles is 263 Wh/mile and that includes a 3100 mile road trip, mostly at 80 mph with the AC on.Just wanted to add something else --- if you're in stop-and-go traffic where you go very slowly or go very little, with the A/C blasting, that'll have a dramatic effect on your overall range too. Just in case the AC is the main consumer of your energy. Look at your energy consumption screen (in-car) and the watt-hour/mile should reflect your consumption. The correct number should be around 300 (I don't have a MYP, just a LR, and normally in city-driving I'm getting ~280 without AC, or maybe ~330 with AC).
Averaging ~200 wh/mile is incredible! 75kwh ÷ 200wh/mile ~= 375 miles of range! You deserve a badge of efficiency or something like that.I get like 185 to 240 Wh/mile around town without AC and about 244 Wh/mile at 70 mph highway without AC and like 280 Wh/mile at 80 mph.. My average consumption for 10000 miles is 263 Wh/mile and that includes a 3100 mile road trip, mostly at 80 mph with the AC on.
My last 3800 miles which was around town and my commute to work is like 246 Wh/mile.
I'm in no way a slow driver.. I just take it easy on AC use.. I usually drive 5 to 10 mph above the limit..
View attachment 708768View attachment 708769View attachment 708770View attachment 708771
All I'm doing is to stay away from the AC as much as possible.. AC is a huge range killer around town..Averaging ~200 wh/mile is incredible! 75kwh ÷ 200wh/mile ~= 375 miles of range! You deserve a badge of efficiency or something like that.
What app is this?It all comes down to accessory use.. In NYC without AC or Heat, you should get rated range. Heat or AC will kill your range in city traffic..
I average close to rated range with my MYLR while people in my area get 74% efficiency. I don't drive slower but despite being in Florida, I rarely use the AC.
This confirms that I drive the same speed as others and have a 24% higher consumption.. So, AC use, will take about 24+% off your range if about half of your driving is in the city. I have a very high tolerance for heat.. Doesn't bother me.. 24 years in Florida..
