ucmndd
You can’t use stranded wire!
lolwut
Find me some solid core #6 thhn readily available for sale.
It’s all stranded at this gauge. Solid core would be impossible to work with. This is why ferrules exist.
Loctite isn't necessary. Secure connections are ALWAYS necessary regardless of how much you spend on the outlet.For the comments made, the outlet itself doesn't seem to be the issue, even the crappy Levitons. If you tighten the wires good, use blue loctite on the screws, use awg 6 wires (good for 60 amps), never remove the 14-50 adapter, and you only charge at 32A max (what the UMC allows), you should never have any issues, no?
YesSo, how do the ferrules help? Prevent stray strands
Yesor does it provide a better connection
Not quite, more like this:And, is this the kind of ferrule you're referring to?
https://www.grainger.com/category/electrical/electrical-supplies/wire-connectors/ferrules?attrs=Wire+Range|6+AWG&filters=attrs
YesAnd of course, you need a crimper.
I tried and it burned also. Had sold core put in and no problem now!You can’t use stranded wire!
At the troll store?
Hired electrician. He took care of everything including running solid core wire from panel to garage to new outlet for $450.... where did you find solid #6 insulated wire?
You're talking about this like lugs and ferrules are two totally opposite things, and it should be only one or the other, but that's not right. They accomplish different functions, but they are very commonly used together.I'm probably wrong, but "ferrules" to me implies low voltage circuits. Lugs are for line voltage applications.
You know what, I retract everything above and would hope that ferrules not be used to terminate the field wiring to the receptacle. The stranded wire and receptacle have both been designed to work together. Why introduce another connection? Save the ferrules for terminating fine standed wire to meet NEC.
Yeah, pretty sure there's no such thing as solid 6 AWG.
