paulp
It would have to be in a tesla decanter at leastA whole coke? Are we talking a fancy glass bottle one? Such confidence
>>lidar system is like a set of guarantees on the vehicles position relative to the environment. With a lidar stack, you can guarantee that it won’t hit a curb (assuming HD map is up to date) as it has a ~mm accurate 3D map of where the curb is ahead of time.<<
I think I will stretch to a glass bottle.A whole coke? Are we talking a fancy glass bottle one? Such confidence
Let's say there is some civil works that happen in between when the mapping was done and when the car drives. If that civil works extended a curb by a few CMs then all of a sudden you will be clipping that curb every time. That is of course unless you have a camera that looks for the curbs and when it sees that the curb has changed it will adjust the car's path to avoid it. Well then why do even need LIDAR in the first place if you require a back system that must be perfect in case the HD map is out of date?I would hope the car ISN’T using mapping in that way! Even tectonic plate movement in many parts of the world would make maps invalid at that accuracy quite quickly!
And keeping global mapping current enough would cost billions a year.
You are just as likely to catch a glimpse of the second occluded vehicle and use a NN to predict its trajectory than you are being able to reliably filter radar returns that have bounced under the lead car.Lidar is line-of-sight. Can't see through fog or bounce under car in front to see occluded second vehicle.
Anyway, Tesla is not replacing radar with lidar, it's just replacing radar with improved visual software. That improved visual software relies on the cameras, which aren't ready yet.
Let's put it another way: if we ever see a fleet of robotaxis on AP3 I will buy you a coke.
Are we talking globally or Australia? If globally, what are the time bounds? I think I'd win a bottle of coke if its globally in the next 5 years.I think I will stretch to a glass bottle.
The radar can see into a fog bank and slow down gracefully for a hidden obstacle.As for the fog, this keeps getting brought up and I really don't understand it.
Isn’t that why aircraft use radar? although they typically steer around rather than brake gracefullyThe radar can see into a fog bank and slow down gracefully for a hidden obstacle.
An example of a hidden obstacle would be a robotaxi without a radar whose cameras suddenly all went gray and had to slam on its brakes because it had no way of knowing if there was a hidden obstacle ahead in the fog.
I suppose you can close your eyes and reverse parallel park using only sonar beeps by your logic?The radar can see into a fog bank and slow down gracefully for a hidden obstacle.
ShockonT never suggested tht the car would work on radar alone, so your suggestion of reverse parking with sonar and eyes closed is pointless and irrelevant.I suppose you can close your eyes and reverse parallel park using only sonar beeps by your logic?
You can’t see through fog. That much is true. However *most* of the information the autonomous car needs to drive exists in around visible light wavelength spectrum. You can’t rely on human intuition to augment radar (like humans do). The car has to have the passive optical receptors in order to make inferences about the world around it.
once you have that constraint, the radar return is like being served the salt and pepper without a meal.
He wrote “drive into a fog bank” to me that means zero visibility hence my analogy. So assuming you are relying on this radar ping through the fog to make a driving policy decision then yes, you are effectively driving on radar alone in that instance because you are trusting radar over vision . If you are not relying on it, then you have to be driving within the capabilities of vision anyway so radar is redundant.ShockonT never suggested tht the car would work on radar alone, so your suggestion of reverse parking with sonar and eyes closed is pointless and irrelevant.
A fully autonomous car that is capable of driving normally around a city does not exist yet. That is an undisputable fact. Your claims of how (mass use) autonomous cars work are therefore hypothetical. ‘Has to have’ for example. Only in your hypothetical theory. You have zero evidence that the future will make this a ‘has to have’.
There is no level 5 vision only autonomous car driving aound the streets. Apologies for not making it clear that my point was for vision only systems. You also may like to review the tesla response to its FSD beta to the USA DMV enquiry. Tesla described it as level 3 at best. In any case, I’m fairly sure you’ll find all the brands you mentioned are supervised under strict DMV licencing controls. They therefore are not level 5 autonomous, but rather systems in development and testing to be autonomous, hopefully.He wrote “drive into a fog bank” to me that means zero visibility hence my analogy. So assuming you are relying on this radar ping through the fog to make a driving policy decision then yes, you are effectively driving on radar alone in that instance because you are trusting radar over vision . If you are not relying on it, then you have to be driving within the capabilities of vision anyway so radar is redundant.
By the way; this is assuming the radar even works through dense fog which is a HUGE assumption. Infrared sensitive cameras might work better but jury still out on that one
yes there a fully autonomous cars driving around on city streets right now. Waymo have a commercial level 5 system operating right now with no driver. Zoox, MobilEye, Cruze and others have autonomous vehicles driving in multiple cities right now. Tesla FSD beta also is capable of driving through a city environment autonomously with driver monitoring. So no that’s not an “undisputable fact”. You are just demonstrating your ignorance and lack of understanding.
In none of those autonomous car systems is radar or lidar ever used exclusively to drive the car. However there are already thousands of Tesla’s without radar driving autonomously on highways right now (I.e navigate on autopilot for June built model y and model 3). Soon (as soon as a few weeks) there will be FSD beta cars driving around in cities not using radar at all either.
On the Tesla front, there are millions of cars with HW3 that are able to evaluate the camera performance versus radar. I would therefore call the data on this “mass use”.
You did not write level 5 vision only autonomous car. You wrote "A fully autonomous car that is capable of driving normally around a city does not exist yet." As that is patently not true, it is reasonable to say that the person making such a claim is ignorant and lacks understanding in the area of autonomous vehicles.There is no level 5 vision only autonomous car driving aound the streets. Apologies for not making it clear that my point was for vision only systems. You also may like to review the tesla response to its FSD beta to the DMV enquiry. Tesla described it as level 3 at best. In any case, I’m fairly sure you’ll find all the brand you mentioned are supervised. They therefore are not level 5 autonomous, but rather systems in development.
Also, “You are just demonstrating your ignorance and lack of understanding.” does nothing other than convince me you are pretending to be knowledgable. Its a known response in such circumstances. You may also choose to note that no-one during this discussion other than you has made snide remarks.
Do you own a tesla?
In relation to your 2nd last paragraph, have another read of my post. Its adequately explained.You did not write level 5 vision only autonomous car. You wrote "A fully autonomous car that is capable of driving normally around a city does not exist yet." As that is patently not true, it is reasonable to say that the person making such a claim is ignorant and lacks understanding in the area of autonomous vehicles.
So now you are just moving the goalposts by changing what you said to "There is no level 5 vision only autonomous car driving aound the streets."? Even on your do-over you are still wrong. Maybe try changing what you said a 3rd time and see if that sticks? Let me guess, next time it will be "bUt sAfEtY dRiVeRs!!!". Hate to burst your bubble but having a safety driver does not change the SAE level and on that point, the SAE levels are bullshit. Waymo, Cruze, MobilEye, Zoox, Tesla are not developing a level 1,2,3,4,5 system, they are all aspirationally trying to solve autonomous vehicles that are on a statistical basis 10x safer than a human. No human is even Level 5 and is by definition impossible to demonstrate, so using that as some sort of "gotcha" when arguing, again, shows ignorance in what the industry views are.
On the DMV emails, what Tesla have done, brilliantly mind you, is the create a fully autonomous system under the legal definition of a Level 2 ADAS. That way they can accelerate the development by getting into consumer's hands faster, collect more data and then iterate faster to improve. A virtuous cycle nobody else has. The only way you get from Level 2 to "Level 5" is by collecting enormous amounts of data and then demonstrating that under computer control, the KMs per accident are 10x that compared to under human control. Only then regulators might allow it to be driverless with certain constraints to increase safety even further. Note 10x safer than human doesn't mean perfect, far from it, but once proven it would be highly unethical to not increase autonomous robotaxi usage as much as possible in order to save as many lives as possible.
MobilEye Vision Only fully autonomous 20 minute drive in a busy street:
"12 camera sensor suit no LIDAR, no radar"
where is the LIDAR & radar only drive if radar and LIDAR as so foundational to solving fully autonomy?
Also Tesla have ADAS drivers in the U.S in soon the E.U testing "Vision Only" FSD (i.e FSD Beta v9) right now. There are general public drivers who are using NoAP which is arguably Level 4 on the highway, vision only, right now. In a matter of weeks (hopefully), you will see dozens of YouTube videos of V9 FSD Beta doing supervised autonomous drives through city streets-- again-- vision only FSD.
By the way, what specifically leads you to think I am pretending to be knowledgable?
yes I have a Tesla (Model 3 SR+) with FSD. I note you refuse to purchase FSD. Seems to me you are trying to justify your position in having not bought it?
Cool story bro.But given I own two debt free model S, multiple tesla batteries, and a significant solar array, it could be that I’m more interested in tesla’s pursuit of environmental outcomes than systems that supposedly make me, a driver that has never crashed, safer for the roads.
Bit of a lesson in life for you. Before you write rubbish. Stop. Relax. Go for a walk. Gain some perspective. think about the fact that you dont know squat about the person you are about to write rubbish about. Then type furiously to get it out of your head. Then press delete.Cool story bro.
Maybe if the mission of Tesla is accelerate the world’s transition to sustainable energy it would make sense that each EV is utilised for as many KMs as possible (I.e autonomous ride hailing) and not just appease you personally?
What are your multiple debt free model s’ doing to contribute to “environmental outcomes” if they spend 90% of their useful life parked in your garage? If somebody could increase the net environmental outcome of their Tesla 10 fold by allowing others who are less fortunate than you to travel emission free — shouldn’t you be cheering that outcome on over selfishly wanting your own Wishlist of free software enhancements to be prioritised ?
Perhaps the strategy to achieve this autonomous vision is to create a compelling ADAS to generate enough revenue to drive a flywheel of progress to an ultimate goal of full autonomy? There are, shocking I know, people out there who have paid the cost for FSD and are completely satisfied with what they have now and they haven’t even seen the final product yet?
If you placed Tesla’s ambition for environmental outcome above your own personal benefit, maybe you wouldn’t be so critical of FSD and it’s progress. This is something that nobody has ever done before, it’s incredibly difficult to estimate with any certainty the timelines of how things will progress. Is an iota of respect and credit deserved for the thousands of men and women making it happen? There are constant technical challenges and set backs yet they preserve despite the drone of clueless neo-luddities telling them how to do their jobs.
Btw paulyp before you have a giant sook, I am not calling you a neo-Luddite there are people much worse than you, however you really should try to do better if you really want to convince other people—and not just yourself— that your interest in the environmental outcome of Tesla is not contingent on it benefiting you personally.
It doesn't matter how an EV is charged, its per KM emissions will always be lower than a combustion engine. Therefore, in order for an EV to be most effective at reducing overall emissions it needs to increase its share of the global total of all KMs travelled.The pause also gives you time to contemplate what happens to the renewable energy that my cars dont need from my solar when not in use, and the benefits that creates, and how a robotaxi will charge when used all day. Bit of nice dirty grid dc power presumbly, supplemented by the exported energy my car isnt using.
BTW for anyone who's interested in more info straight from the horse's mouth, here is a talk from a few days ago from Tesla's AI Direction Andrej Karpathy
