sleepydoc
The only cars I’ve used with such a shift knob were a caravan and a hyundai (both rentals.) in both of them the knob was at least 1.5-2” in diameter so it was easy to grab without looking. THey also had detents that one could feel when turning them so it was easy to shift by feel.But the thing is the type of small shifters he is talking about, they aren't big enough of a target to use without looking at them. He's not talking about the big shifters of the old days.
And that reminds me, even the old shifters, I looked it up before and people actually typically look down at them to change between drive and reverse:
Looks like they are removing stalks from the 3/Y
It doesn’t look like a horn icon to the upper left of the right scroll wheel. Maybe a phone button? Maybe they finally put the horn back in the center airbag? The horn button has been relocated to the brake pedal. One quick tap for horn. Steady pressure to brake. Simple, intuitive, futuristic...teslamotorsclub.com
There are probably very few people that do it completely by feel alone.
Most common gear shift designs follow a common pattern - P - R - N - D. You shift down from park to reverse to back out then 2 more clicks to put it into drive. The shifters also automatically stop in drive so it’s incredibly easy to do even blindfolded. The Tesla shift stalk is the same way - detents make it easy to put into drive by feel.
I like how people who can’t form a cogent counterargument resort to ‘you’re a luddite who can’t adapt to change.’ If I didn’t want to change I wouldn’t have bought a tesla. Nor would I be using FSD. Implicit in your post is the argument that all change is for the better. Clearly that is not true. My satement about 100 years of automotive design has nothign to do with change, it’s an empiric observation that turn signal stalks work well and are clearly preferred. Do you really think no one has considered getting rid of them before Elon? The technology to do so has existed for at least the last 50 years.Every single one of those points should end with "for me". (Except the gloves problem. That's a real issue)
They are your opinion based on your experience, which is perfectly fine, as that is what this post was for.
But don't write your opinion in the form of fact. It's only your reality based on your experience.
Saying that stalks have been an industry standard for 100 yrs tells me exactly where you're coming from.
The root cause of your "review" comes from being stubborn about change.
It sounds like you just want an ICE car that happens run on a battery.
Tesla has never been that (exception to original 'Lotus' Roadster). The whole reason Tesla has been successful is because it pushes the idea of what a car can do/be to it's limit. And all that's done is drag the rest of the auto industry into the EV era. It wasn't going to happen otherwise. And sure, when you take big swings, you're going to miss sometimes. But it's more important to take those swings!
I do wish they waited until they had steer-by-wire to remove stalks. It would have helped since you wouldn't have to remove your hand from the wheel as much, but oh well.
I've said it before, going forward, any new drivers that learn how to drive in a new Tesla don't have the old habits of using stalks or gear shifters. They'll learn without them, and won't have the biases that older drivers do.
Reaction time won't be worse, because they aren't unlearning the old way.
It comes down to how open are you to learn a new (better or not) way of driving.
If you're unwilling to adapt, don't buy it.
My analysis was as objective as I could make it. (Please explain how finding some buttons on the steering wheel when your hands are not at the 8 and 4 o’clock positions is easier or quicker. I tried multiple times. Could I do it? Yes. Was it easier? Absolutely not. If My left hand was off the wheel it was far more difficult and slower. This is not opinion, it is fact and I challenge you to disprove it.
Elon has taken many big swings. He’s hit some bombers and he has whiffed many times as well. This is an example of him swinging for the upper deck and hitting himself in the ass with his bat.
