Due to information/product vacuums caused when Tesla allegedly stepped in and prevented further sales of Korean CCS1 adapters to North America (e.g., by helpful businesses like Harumio), several new potential sources of adapters originated in 2022.
September 21, 2022 Update: Tesla North America has (finally) released the CCS1 adapter to its Canadian and U.S. customers. The adapter is available to all (four) Tesla models, provided cars are CCS-enabled. Hardware/software retrofits are coming in 2023 for cars currently without CCS capability.
* Includes shipping to North America.
Note: Adapter images are not to the same scale.
Comments:
* @wk057 has a bench-top dissection of a CHAdeMO adapter here, showing all the control circuitry necessary (hence the CHAdeMO adapter's larger size, by the way).
Disclosures and Alerts:
"New" (in 2022) Sources of CCS1 Adapters
(Grouped by type.)
(Grouped by type.)
Source | Price | Specific Notes | Availability (in NA) |
Genuine Tesla Adapter | |||
$250(US) $340(CAN) |
| AVAILABLE. | |
Tesla-Adapter Copies | |||
$294 $319 $250 $235 $246 $251 $239 $216 $230 $203* |
| AVAILABLE. | |
$200 $170 $185 |
| AVAILABLE. | |
Independently-designed Aftermarket Adapters | |||
$270 $227 $195* |
| AVAILABLE. | |
In Development | |||
-na- |
| Currently Unavailable. | |
Comments:
- USE FOR AC J1772-PLUG CHARGING? - Unfortunately, (some/all) J1772 plugs can be inserted into the upper circular socket of CCS1 adapters. This perpetuated the misconception (among some) that CCS1 adapters could be used to accept J1772 plug-outfitted charging cables. Untrue. CCS1 adapters are exclusively for DC charging. In contrast, J1772 plugs are used for AC Levl 2 charging. I surmise that none of the CCS1 adapters listed in this post are usable with any J1772 AC cable-plug device. No CCS1 adapter is necessary for AC charging (from 240v wall outlets and at Level 2 charging stations). TMC members have convincingly demonstrated (via photographs) that Tesla and aftermarket CCS1 adapters seen so far lack certain key electrical connectors necessary for AC J1772 charging (see here). For a North American Tesla, you can use charging equipment with J1772 plugs only with a proper J1772 adapter.
- CHARGING LOCKS - Adapters designed for use in North American Tesla cars routinely come with a locking notch (at the bottom of the Tesla proprietary [TPC] plug that inserts into the charging port) that will prevent most unintended adapter-removal (i.e., theft) from the port during a charging session. Some manufacturers/suppliers are also addressing the second undesirable issue of having a CCS1 cable-plug/handle prematurely removed from the other end of the adapter during charging. See individual supplier webpages about any features designed to prevent undesired cable removal.
- INTERNAL DESIGN - Most third-party CCS1 adapters appear to have a relatively simple straight "pass-through" circuitry design (with no or minimal amounts of solid-state circuitry components), as does the OEM Tesla adapter (I believe). The original SETEC adapter--with its battery-powered, CHAdeMO-mimicing software/hardware and 50kW charge rate maximum--is the notable exception.
- CCS COMPATIBILITY - CCS1 adapters that lack on-board control circuitry (i.e., most/all adapters other than the original SETEC device) require that the car be "CCS-enabled." (In other words, some kind of CCS-allowing control electronics must be present inside either the adapter or the car.) In general, most Teslas from early 2020 to June 2021, and from November 2021 to present are so enabled; but check your car's CCS status before purchasing an adapter.
- To check CCS status:
- Center Touchscreen Display.
- "Software" screen.
- Choose "Additional Vehicle Information" link.
- Examine "CCS adapter support" status. Status should appear as either "Enabled" or "Not installed."
- If "Not installed" (CCS incompatible), there may be DIY (do it yourself) workarounds, or you can wait for Tesla to sell service retrofits (as was done in Europe for CCS2 adapters there).
- ADVERTISED CHARGING RATES - For several reasons I am no longer reporting charging rate specifications; in part because the new (2022) adapters all claim a maximum charging rate of at least 150kW, up to 250kW (as does the Tesla OEM adapter).
TMC Forum posts report widely varying charging rates for seemingly all CCS1 adapters (both Tesla and third-party). The reason is apparently that many conditions and factors--e.g., car model, age, and condition; the battery's initial charge level and temperature at the start of a charging session; and additional factors--may affect maximum and ongoing charging rates. Clearly the design and condition/health of the particular charging station being used makes a difference (with variation even seen among charging stations of the same company and at particular stations on different days). Also important: exactly when a reading is taken during a charging session. Charging rates rise and fall naturally over the course of a full session (here is one example). When a car starts with a relatively low battery level (say at 20% capacity), a moderately-high start, followed by an aggressive ramp-up, and then a gradual decline to completion is not unusual.
Taking all this into account, a single charging rate index number may not be a particularly helpful (or honest) decision-making factor. Better, perhaps, would be a series of comparative charge-session graphs with conditions held relatively constant (e.g., 20%-to-80% charge sessions, batteries preconditioned to best operating temperatures, moderate ambient temperatures, use of the same charging station, etc.). Clearly we need someone like Tom Moloughney (YouTube "State of Charge" Channel) to objectively test, side-by-side, all the CCS1 adapter alternatives. In addition to comparative charge rates, I would also be interested in internal design, and build quality. (But I certainly do not want to dissect* my own, or indeed any, precious CCS1 adapter to investigate.)
It is still early days, but one (still untested, afaik) hypothesis is that adapters with straight "pass-through" circuitry designs (including the Tesla OEM device) will all perform in generally similar fashion given the same conditions. If that proves true, the choice of product then comes down to factors other than maximum rate of charge; such as build-quality, safety features, cost, size and weight, availability, brand loyalty, purchase convenience, customer service, and so forth. I haven't looked inside an adapter, but I imagine that the size/bulk, design, and metallurgical content of electrical contacts and conductors will prove to be important (e.g., for resistance and hence energy loss through heat). This is DC high-voltage fast-charging, so you want beefy components here, people. Consider the analogy of purchase of a NEMA 14-50 wall receptacle from among several brands with different prices and/or construction/designs. They all work, but...
- CAVEATS - Information (e.g., prices, descriptions) on some sites can change frequently and unexpectedly. Some initial products--and even one website--are no more. Again, be cautious. After a long wait, adapters are finally available from Tesla in North America. Therefore, many might now argue that the genuine CCS1 adapter (and factory hardware retrofits needed for some cars) from Tesla in North America are the safest course. But will Tesla supplies be consistently adequate to meet demand? We'll see. (As of 11/21/22, Tesla's ongoing stock of CCS1 adapters apparently continues to be satisfactory.)
- CURRENCY - Prices listed here are in US dollars.
- CAUTION - Please note the alert (in red) at the bottom of this post.
Prior Sources of CCS1 Adapters
(In order of release?)
Source | Price | Specific Notes | Adapter Type | Availability (in NA) |
$525 |
| "Aftermarket" Straight "pass- through" circuitry. | Currently unavailable. | |
$640 |
| "Aftermarket" Hardware/software used to mimic CHAdeMO technology. | AVAILABLE. | |
~$239 (US) |
| "Tesla OEM" Straight "pass- through" circuitry. | AVAILABLE (in Korea). | |
- In 2022 I purchased two Tesla-Korea CCS1 adapters, along with aftermarket cases for those adapters, from Harumio in South Korea. (I found the process painless and convenient and staff there helpful and professional.) I paid the standard Harumio retail prices. I do not own, nor have I seen or handled, any of the other CCS1 adapters.
- More importantly, I have not received, nor am I or will I be receiving any payment or compensation in any form whatsoever from any company or individual regarding CCS1 adapters (or for that matter any other Tesla- or auto-related issue). All opinions, right or wrong, offered in this post are my own.
- The third-party CCS1 adapter market continues to be competitive. Product specifications and information (especially availability and prices) can evolve suddenly and unexpectedly as the market adjusts to recent events. Therefore, information included here may be in error or out-of-date. If you choose to purchase a third-party product, always check with the seller for the latest information and discounts before buying. As with other Tesla-applicable accessories, consumers now have a choice of factory or aftermarket products.
