If you start at the foot of a mountain and you go up path, will the path go up forever, since it did so for the lat few hundred steps?
While I still do think it will increase in power, your explanation makes no sense at all.
If there are 74 in parallel, they provide a 74th of the amperage, not the power. Every cell provides 1/7104th of the power, no matter if they are all in series, or all parallel. The power, or the internal losses don't even change, if we just look at the batteries, if we switch from all parallel to all series. And why should the 90kWh pack should use more cells parallel. The voltage would drop if they did that. I guess the cells still have the same voltage, but a higher capacity. And the notion that you can pull more amps out of a higher amp hour cell is just wrong. It is true if you have a bigger cell, or look at a pack with more cells in it, but other than that its just wrong.
It would be nice if we could solve all our battery problems with fractions, 7/12, 18/4, 99/263... but it really isn't that easy.
