On a different note.......
I just got back from the Service Center where the folks were kind enough to flip me a key for a V2 P90DL (you know who you are an you rock). I promptly moved the car to the super charger and topped it off with Max Bat enabled. That was followed by a little test drive.
From my non-calibrated butt dyno, the 0-40 feel was about the same as my P85DL +/- a bit. I've got lighter wheels and better rubber which likely helps with the consistency I feel with my car.
The 0-100 is WAY better. The V2 car pulls much better above 60 than my car.
Punching it from a steady state 40, 50, or 60 mph is WAY WAY better than my car and is much closer in line with some 650 to 700 hp cars I own or have owned in the past.
I've not collected data but I suspect Tesla is close to, if not exactly on, the current ramp used on my car. This would explain the very consistent launch and lower speed feel of the two cars. Data has already demonstrated on other cars that Tesla is in the 500 KW range (670 hp by my math) and this is backed up by the feel of the car beyond the initial current ramp.
Sure would be nice if the V2 battery would work with older cars. The P90DL I drove has the same ole floaty MB air spring damper valving I learned to loath in that other brand. I was over the moon happy when the chassis engineering guys said I would be thrilled with the P85D valving. They were right and, as much as I love extra power, I refuse to give up quality feedback from the road (not to mention putting up with sea sickness
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
). You use the power once in a while. You live with the suspension every single minute.
Now back to the regularly schedule arguments to which I will add-
I've come to the conclusion that there is a troll amongst us. Just add up the words typed and you will find the culprit.
And no, I do not have a need to file suit against any and everyone I have a disagreement with. That would just flat be a pathetic existence.
