AMPd
Mine lost sound but the actual turn signals still worked. 2015 model sSomeone on reddit said older cars lose turn signals when the MCU goes. Not sure if thats true. I know mine loses sound, not sure about the lights
It will fail permanently on the next update or in a few months if you skip updates. They have 2 partitions and each update moves from one to the other. When it fails on one they fix it by moving you to the other, but that only works once.Mine actually went out last weekend and luckily Tesla reset it without replacing it, but I'm told this may be an indication it will need to be replaced. It could be part of the reason for me to replace my aging 2013 P85+
NHTSA considers failure of light controls to be a safety issue.MCU1 failure is an expensive nuisance to fix, to be sure, but I think it is a stretch to call it a safety issue, even with climate control and window defogging being unavailable.
I don't expect any help from NHTSA.
I got home and the next day everything was normal. All the screens worked as usual.Did you eventually get it fixed? or is it still like that?
So we can chalk it up to reporters not reading, as usual. Shocker.....The actual text from NHTSA: 2014 TESLA MODEL S:
So they know it impacts the Model X as well. (And goes to early 2018.)
The MCU controls sound, so the turn signals work and flash on the IC but don't make a sound. Once the dead MCU is replaced everything is back to normal.Someone on reddit said older cars lose turn signals when the MCU goes. Not sure if thats true. I know mine loses sound, not sure about the lights
That's a valid question. Why 63,000? That number does not account for any one single year from '12 thru 1Q'18. And its not a combined count for any two years. For instance, 2015 sales were 51,773 so where's the other 11,000+ counted from?First thing I thought on reading about this today was 'why not include Model X's' and why not every model year up to the MCU 2's? Nothing was ever done to upgrade the MCU 1's, so, why do an incomplete investigation/analysis? Or have I missed something?
You may be right but isn't that the same as the climate control system breaking and you need to park the car until you can get it fixed or limp along as best you can (and did)? I guess I think of a safety issue as the brakes or steering or headlights going out while driving (point of curiosity: what happens to the lights and wipers in the Model 3 when the MCU dies?).I beg to differ. I was driving In California during winter of 2019 and the MCU experienced an endless reboot that Tesla support couldn’t fix. Manual reboots didn’t work either. I had to manually defog before I first got in. And when the windshield fogged up to the point I could not longer see while driving, I had to pull over to wipe. It was definitely a safety issue.
Do not fool yourself in believing a response from the feds is coming soon. This will take years to flush out.U.S. probes touchscreen failures in Tesla Model S cars
Hopefully they are forced to recall and repair cars with mcu1.
Yep, unless Tesla decides to do it voluntarily. (Which NHTSA just opening a PE might be enough to push Tesla into doing the right thing.)
Come on, we all know the number is far greater than 11 and extends all the way until 2018 when MCU1 was discontinued.
Everyone who's had to replace their MCU1 should file a complaint with NHTSA now.
Thanks for the source link. I was able to get the facts of the investigation:So we can chalk it up to reporters not reading, as usual. Shocker.....
Thanks!
