I read they have gone way up in price, like most used carsI wonder what the used price is. When I was first looking at EVs I looked at an old Leaf. It was really, really cheap, $7K for a 2-year-old model with under 12K miles. But it sat and sat so I decided not to buy it.
THe folks I am talking to are a lot more money. Again, if you want to add stuff, you are at mercy of who put your stuff ini got a $100 bill i will sell you for $10K
first powerwall 12,500, 7500 for each additional...
i need to buy one, hook up in public space and have it drain your battery!
Yep, I just did not say it made sense money wise, but yep, solar max first!!!but your the guy who says install more solar then powerwall...
If it can be made to do V2H for not much, you are in no matter what as it should be paid for by now.My leaf is a 24khw pack. I figure 25-30% degraded though.
I just order an iPhone Pro Max. Same thing?Is that a new product?
Well, one thing as an additional expense here is this is a 480/277vac application. You will need a properly sized transformer if you plan on installing this at a residence with 120/240 split phase power. Depending on whether the charger needs 3 phases you might have to do some phase conversion magic, which is also probably expensive.So, this seems to be a much cheaper and great capacity solution than batteries? I am trying to find cost of charger and specs to hook up.
Nissan Approves Charger That Can Draw Energy From LEAF To Power Your Home | Carscoops
The Fermata Energy FE-15 allows owners to power a building during peak hours and charge when it's cheaperwww.carscoops.com
More than simply a generator, the bi-directional charger is actually hooked up to the grid, allowing it to send energy back into the power grid in states with utility demand response programs, which could allow owners to get paid for their power.
Rereading the datasheet, it requires line to neutral-voltage of 277 vac. So no phase converting needed.Well, one thing as an additional expense here is this is a 480/277vac application. You will need a properly sized transformer if you plan on installing this at a residence with 120/240 split phase power. Depending on whether the charger needs 3 phases you might have to do some phase conversion magic, which is also probably expensive.
I am curious how Nissan would modify the Leaf warranty if I were to use this device? Anyone ask them?
If its 480, then I would not work. Which would be great since I could stop researching, and wife would be happy. But, will see if they ever call. I might try to call them this week and just put to bedWell, one thing as an additional expense here is this is a 480/277vac application. You will need a properly sized transformer if you plan on installing this at a residence with 120/240 split phase power. Depending on whether the charger needs 3 phases you might have to do some phase conversion magic, which is also probably expensive.
240 X 480-120/240 Volt 1 Phase TransformersIf its 480, then I would not work. Which would be great since I could stop researching, and wife would be happy. But, will see if they ever call. I might try to call them this week and just put to bed
It will be interesting to see if you can get the leaf integrated into your system and have it play nice with your powerwalls. I imagine that will be your greatest difficulty.I am getting more serious about maybe buying a leaf. Looks like this charger works for residential and will be shipping this year. Its not cheap, for a 2 head model, 8K, but what the heck.
