Mercury_CZ
New Member
Same here, our Tesla found 2023.26.8 after I restarted system and restored connectivity before I jump to the menu. Last time of update check was five days ago.
Dunno, TeslaFi says 26.10 has 11.4.4Heard via news, prior to v12, 11.4 folks and 11.3/26.x will be merged into one code of 26.10/11.4.7,8
Anyone else heard this?
Yep, this is just how it works now it seems. I checked the software page again just now, last checked on the 19th (it’s the 28th today). I changed the display language and it’s immediately downloading 26.8.Best way is to just change the display language. It does a much quicker reboot (maybe 10 seconds). Like the guy above, the only time I've received updates since getting the car a month or two ago is by doing a reboot or the language change reboot. I'm experimenting with it at the moment and purposely avoiding the language change reboot to see if I'm offered it (it's rolling out a lot where I am at the mo). I suspect I won't until I do the reboot.
It’s another hack idea to force an updateAre you guys multilingual or just choosing a different language, then changing back?
The system reboots when you change the language.Are you guys multilingual or just choosing a different language, then changing back?
Just toggle between English and British EnglishAre you guys multilingual or just choosing a different language, then changing back?
Then it would be easier to just do a normal language change, would it not.The system reboots when you change the language.
Aah sorry, that is just me being silly.What do you mean normal language change?
Changing the language will reboot the system but you also need to change it back to your desired language so you’ll need two reboots.
Or just so the two button reset to reboot once.
I don't to be honest, I just change it to British English to get the current software to download, leave it on that until the next update comes out then change it to English. Rinse and repeat. The only thing that changes really is Bonnet and Boot instead of the american versions (I can't remember now, frunk and trunk I guess?)What do you mean normal language change?
This worked for me. My car did its last check on Jul 20th, stuck on 2023.26.7 and would not update even after a reboot. LIke you, I changed to "Standard" and it was set to "Advanced" after the reboot.I've been having this issue over the past month, and was way behind the adoption peaks for new software releases, which never happened before. It was driving me mad. The last update check was many days ago, while usually I could check every 24h. I found a workaround yesterday via trial and error, maybe it also works for others.
Workaround:
- Set your Software Update Preference to "Standard" (see below why)
- Do a soft reboot by holding the 2 steering wheel buttons
- Important: don't immediately go in the settings after the reboot. Wait until the car gets connectivity, which can take minutes with LTE.
- Go to the software updates section in the settings. The Software Update Preference, for me, was curiously automatically set to "Advanced". The software update check should be triggered.
2 hypothesis about the root cause.
- The "Advanced" software update preference was not properly saved/applied, or got corrupted after an update, and flipping the setting + rebooting solved it.
- Manually checking for software updates without connectivity may cause the feature to fail, even when trying again later with connectivity.
Sounds like there could be more than one issue going on here.This worked for me. My car did its last check on Jul 20th, stuck on 2023.26.7 and would not update even after a reboot. LIke you, I changed to "Standard" and it was set to "Advanced" after the reboot.
