OI will charge any scheduled charging outside the designated 6 hours at the cheap rate. From OI faqs:Do you mind me asking, I was under the impression that they apply a fair usage policy of only 6 hours of schedule charging. In circumstances like this when the app schedule charging for more than 6 hours, do they really charge the full rate on anything that is over? Thank you
Thank you for your reply. I might have confused you on my intended question. In the TC it says that IO is subjected to a fair usage policy with a maximum of 6 hours of managed charging per 24 hours. My question is that if it schedules to charge more than 6 hours? (if all outside the off peak windows), will we be billed the day rate of anything that is over the 6 hours? As I have come across a couple of times the app is going to charge my car for 8 hours but that is before 23:30, so I am not sure if I should take that or stop the charge after 6 hours. ThanksOI will charge any scheduled charging outside the designated 6 hours at the cheap rate. From OI faqs:
Plus, when we schedule your charging, you’ll always benefit from the low rate for EV and home, even if we happen to ask your car to charge outside of the standard night hours.
No, it has all been billed off-peak to date. I think the clause you refer to gives them scope to limit it to 6 hours in the future, but Octopus are very much in data gathering mode on this relatively new product. I expect it to stay like that during beta.My question is that if it schedules to charge more than 6 hours? (if all outside the off peak windows), will we be billed the day rate of anything that is over the 6 hours
It is Octopus yes, I was monitoring it using Teslamate, IO was waking the car once an hour for 15 minutes. When I informed Octopus about this they replied with…..
Like all charging, in order to Smart Charge your car, we will need to wake it up. We plan to back off and let your car go back to sleep (to avoid battery drain) as often as possible.
Currently, we only back off whilst the car is plugged in, as well as when the car is away from home and stationary. Try plugging in your car to send it back to sleep.
If your car is plugged in and it still won’t go to sleep, then this is unlikely to be caused by Intelligent Octopus is keeping it awake. It is likely that something else is causing your vehicle to stay awake.”
So I think it is best to disable smart charging once complete
Agree and why wake the car up when it’s not even connectedits really stupid - once they've set the schedule, there is no need to keep waking the car. drains a huge amount - 3-4kwh a day looking at teslafi.
It's nothing like that once the car is plugged in. It's waking up for around 15 minutes per hour.he car. drains a huge amount - 3-4kwh a day
The problem is being massively overstated. If people can't be arsed manually toggling a switch in an app that takes about 10 seconds to do in order to get at least 2 more hours off peak, they've got different priorities to me.I must admit that on the bais of the above discussion I wouldn't touch IO with a barge pole! There just appear to be too many potential points of failure in its present state (and I have been an Octopus "fan" being on GO, very successfully, since 2019).
That removes one of the key points of the IO system though; the automation. If you have to manually turn it off & on every day to prevent the system draining your car battery it's a fundamental flaw in the design/coding of the system. Other apps that use the API are perfectly capable of letting the car properly sleep but Octopus seem to not be able to figure that out.The problem is being massively overstated. If people can't be arsed manually toggling a switch in an app that takes about 10 seconds to do in order to get at least 2 more hours off peak, they've got different priorities to me.
I never said it wasn't a problem, I said it was being overstated. Of course it needs fixing.That removes one of the key points of the IO system though; the automation. If you have to manually turn it off & on every day to prevent the system draining your car battery it's a fundamental flaw in the design/coding of the system. Other apps that use the API are perfectly capable of letting the car properly sleep but Octopus seem to not be able to figure that out.
It's not difficult logic -
- If car is at home, read car SoC from API
- Set charging windows based on SoC
- Let car sleep
- Wake up at next charging window
- Monitor API for updates
- If car wakes up for any reason & updates API, take SoC reading
- Recalculate windows if necessary
- Let car sleep
- Repeat as necessary
Great stuff. How does one give feedback to octopus? This is obviously a beta product and as a result they should be open to feedback from customers to improve their productThat removes one of the key points of the IO system though; the automation. If you have to manually turn it off & on every day to prevent the system draining your car battery it's a fundamental flaw in the design/coding of the system. Other apps that use the API are perfectly capable of letting the car properly sleep but Octopus seem to not be able to figure that out.
- If car is not plugged in, do nothing, let it sleep
- If car is at home and plugged in, read car SoC from API
- Let car sleep
- Let car sleep
There's a feedback option in the app!Great stuff. How does one give feedback to octopus? This is obviously a beta product and as a result they should be open to feedback from customers to improve their product
No issue at all using the dumb charger. The tariff is doing all the smart stuff.could I still do this via the dumb charger on cheap IO rate?
Now I'm confused. So you just want the six fixed hours of off peak charging by disabling smart charging in the app? Well OK. I'll say it again: this is against the spirit of the tariff and the ToU but I doubt you'll get kicked off it, although they'd be able to.all the talk of the quirks in the IO system and keeping the car awake seems a bit of a faff
Yes, you would need the Zappi for Eco/Eco+ style trickle charging. I have a similar set up my Hypervolt and IO. The IO tariff isn't smart enough to allow trickle charging for solar, you'd need to disable smart charging manually or enable "bump charging" in the IO app.do I still need the new Zappi to facilitate trickle charging the car when the solar is installed
