I recently did a test of the supercharger times at three empty stations in December.
To get the super fast 170 mile charge in 30 minutes you need an almost empty battery. My average was about 135 miles in 30 minutes but two of the stations were not operating a little below full capacity.
Supercharger Time Test | Tesla Owner
Just to add more confusion to the mix of battery pack labels. Here is the label from my replacement pack that was installed end of September 2013.
So yeah if you pull up to to a deserted super charger with an empty battery and you "only" get 90 KW you are still charging 4.5 times faster than a HPWC with dual chargers or 9 times faster than UMC/HPWC on a single charger.
You would also be charging twice as fast as a Nissan Leaf with "quick charge port" Chademo and would still have vastly superior range at the end of even a 30 minute charge at 90 KW. Oh and did I mention you'd have a nicer looking, more comfortable car to use in the process?
youlikeadajuice... now I'm really curious how fast yours will charge at a supercharger... my guess would be 79kW (90*7/8)
I had missed that... so even the 'A' 60kWh packs can charge fast. What's the SN on your pack? How does it compare to the highest numbers posted from people with 85kWh packs that are limited to 90kW?Like I said, my 60 kWh pack as the exact same serial number as youlikeadajuice, and my serial number is earlier. I've seen my car charge at 104 kW, so I'm almost certain that youlikeadajuice's will, as well.
Nice. I posted some of mine in the "finally 120kW" thread a few weeks ago. We see very similar patterns when getting the full 120kW.
Wow, an April delivery with A an pack. And I thought I got unlucky with an A at the very end of December...85kW, Vin 9328, End of Apr '13, highest charge so far - close to 90kW at Gilroy - new SC's - alone.
Ok - here's mine
60kWh pack from a car bought in July but manufactured in May (bought the showroom model the day after my test drive - not willing to wait 3 months):
SN: T13E0012909
PN: 1020422-00-B
This battery can do the full 104kW (120kW*350V/400V).
So if I compare with what youlikeadajuice posted and some of the other pictures I'm concluding that the SN is "T"YYM# where the number is just a linear count regardless of 60 or 85 (for those where we can see the VIN and the battery SN it seems that the Sigs have a slightly higher # than their VIN (accounting for Beta, Founder, and other pre-production models) - and the production cars have a higher offset, but not enough to account for the ~1200 Sigs... (or am I confused assuming that the first production car was P00001... was it P01201 ? )
yeah but his is another B-A. 'B' on the left, 'A' on the right. There are 'A-A', 'B-B', and 'B-A'. So far I think 'A-A' is 90kW, and 'B-B' is 120kW, and 'B-A', I think is 120kW. Is that correct? smartypnz, when did you last supercharge? On 4.5 or 5.8?
I still contend, and have seen no data to the contrary, that the small code to the left is only a revision code for the label. The only "A"-A"'s are very early cars-- US-only Signatures. I believe they rev'ed the label first for Canada shipments, which began with "A" series packs ("B"-"A" in your parlance), then they shifted to the 120 kW-capapble "B" packs. I have seen no evidence that anyone with an "A" in the main "(1P) PN" can charge above 90 kW. I have seen no evidence that part numbers with "B" and above cannot charge above 90 kW.
So specifically, there are many examples above, including my own car, that are "B-A" (bilingual label, but "A" PN). All of those posted are 90 kW-limited.
If I am wrong, by all means correct me with specific evidence!
I believe that at least for 60kWh packages mark1b has proven your theory wrong. His "A" PN S60 charges at 104kW
