Law&Disorder
I'm coming out of a BMW M5 and I think the P85D suspension is very comfortable and even a little floaty. We'll see how I feel when I mount my new set of aftermarket 21"s next week.
So I drove more recent P85D the other day that was produced after April and it's in fact too soft for my tastes. My hair is turning golden with curls but there doesn't appear to be something that is just right![]()
It would be a favor if you would measure the sway bar thicknesses. At least one P85D should yield 24mm front, 20mm rear. AFAIK, it doesn't matter where you take the measurement, as the thickness s/b consistent across the bottom of the car.
My P85D front sway bar is 28mm.
It would be nice to side by side early/newer P85D, load their trunks, to see how much weight it takes to lower the back/frunk 1"(or double a half inch). Last I checked, "spring rate" is defined as the amount of weight required for one inch of deflection. Not sure how to defeat compensating adjustments the SAS might make.
Thanks. I should qualify my 24/20 measurements as front/back, of a 3/15 coil P85D. Early/late SAS could be different. I don't think sways matter as much, in feel, when the both sides of the axle go up and down. Deeper potholes and one-sided bumps would probably be where 28mm could show up as stiff.
[EDIT: 4mm is big. It would be huge, if we were talking about torsion bar springs.]
We've already seen several cases where P85D wheels have flown off when hitting seemingly shallow pot holes.
3) Mechanical safety - The level of firmness makes me worried about metal fatigue of the curved steering knuckle over time. Because it's extremely curved, forces exerted from below do not transfer straight up and down but rather inward, up, and then back out. If you look at the knuckle, you'll see that if you compress it from top and bottom, it must eventually bend
The strut is what bears the weight "straight up", I think, not the knuckle that it is right next to. That might just control the travel.
I didn't know whether the air sprung cars can adjust their compression (spring rate), depending upon which car they are in. If not, than both spring and damp rates are the same for all newer air suspension D's, like people are saying.
I don't believe other makers let people test drive their cars, then change suspensions to something standard, and deliver that instead. I sympathize with these people the most. At some point, Tesla's slack runs out.
woah woah woah, WHAT? who when where?
That's right. More air, higher spring rate. The highest setting is the stiffest and the lowest setting(height wise) is the softest.
