Yes. The D Motors are identical on non-P cars. The reason the 70D is lower performance is because the voltage of the 70kWh pack is lower due to it missing 2 of the 16 modules.
@Ingineer, you'd be the one to ask. Are the inverters in the 70's the same as the Non-P Dual cars? I suspect they are?
Back when I had my classic 85, I kinda urked me that they were charging at the time $10k for a different inverter.
It's not even a different inverter.
Based on my own analysis all of the small motors and inverters (70D, 85D, 90D, front of P85D/P90D) are all physically the same. All of the large motors and inverters (S40/S60/S85/P85/S90/rear of P85D and P90D) are all physically the same.
The only differences are firmware, and relevant battery capability. An S85, for example, could be changed to P85 performance with just software. A 40 could be changed to P85 performance with a pack swap and software.
As a new soon to be owner who is still learning about the hardware of the cars, this is a bit unbelievable to me.
If I'm understanding this correctly, it's not hard to imagine a future where larger 'refurbed' packs are offered at a specific cost which would upgrade not only the range, but the performance of the car.
To confirm, the 70D -> 90D upgrade path would be as simple as a pack swap and firmware upgrade. Correct?
Correct. It's not really all that far fetched when you think about it. Makes a lot of sense from Tesla's perspective. Also makes a lot of sense for them to keep the perception that it's more complicated, even when it isn't.
Wait, didn't Tesla already say before production release back in 2011 that the motors were the exactly same between the P85 and S85? The only difference was the inverter (P85 inverter can do 1200A and S85 can do 900A).Wow....my mind is Blown. I cannot believe the big motors are all physically the same. Wow. P85 & S85, the same (except the firmware). Mind completely blown.
1002633-00-E | ASY,P-TRAIN,MECH,COMPLETE,RC | Standard Powertrain | Between rear wheels |
1002633-01-E | ASY,P-TRAIN,SPORT,MECH,COMPLETE | P85 Powertrain | Between rear wheels |
Right. It makes no sense for them to offer this right now, but in the future when there's v2 and v3 of the body style and sensors, owners with older cars would likely pay for pack upgrades vs. new cars if that was an option. With the Gigafactory running at full capacity, a trade-in of your old pack in exchange for a reduced price on a full car upgrade sounds like a great program and revenue stream for them. Could push the current gen cars to 10 year life-cycles and beyond.
http://www.teslamotorsclub.com/show...-and-P85/page2?p=444202&viewfull=1#post444202
It is conceivable that they decided to make the inverters the same later on to reduce configuration differences (similar to how the 40kWh is a software limited 60kWh).
It should be easy to tell from the part numbers.
Edit (why didn't I think to look at the wiki? performance rear drive unit has a different part number):
http://www.teslamotorsclub.com/showwiki.php?title=Model+S+Parts+List
1002633-00-E ASY,P-TRAIN,MECH,COMPLETE,RC Standard Powertrain Between rear wheels 1002633-01-E ASY,P-TRAIN,SPORT,MECH,COMPLETE P85 Powertrain Between rear wheels
I remember someone mentioning that there is a longer lead time to get a replacement performance drive unit than a standard one. If they are physically the same (only software is different) that seems like a waste of time on Tesla's part (why not have same part number and upload software later).
Front drive unit, I was aware previously was the same physically across all models (only the firmware is different).
Part numbers are different. Motors and inverters still the same. It's smoke and mirrors... or rather stickers and fimware.
I've personally been a part of and have driven a 60 (early VIN salvage repair) turned P85 with just a pack swap, configuration change, and firmware redeploy. Performance was P85 performance. Inverter temps normal, etc.
Hmm. Consensus is that the P has a souped up inverter. The DU otherwise is the same. Pretty sure it's listed differently in the parts catalog so seems there's more to it than software.
Huh, that's surprising. Seems odd though that the part numbers are different.
That's interesting. So Tesla's own techs are wasting time ordering a performance drivetrain if that is true. I wonder however if there are any hardware differences inside (as in you can run the standard inverter at performance level, but it will degrade more quickly than one that is rated for that load, similar to how in a recent thread, transformers can be run above their load ratings).Part numbers are different. Motors and inverters still the same. It's smoke and mirrors... or rather stickers and fimware.
To wk057... in theory, could Tesla release a firmware update that makes the 70S / D faster than the current spec? Is there reason to believe the vehicle is limited by software vs. the battery / voltage output or are we currently at the limits of the car?
To expand on this, I've read the 85 kWh is really a 77 - 78 kWh usable battery. That's an effective 10% increase in usable battery with a 20% drop in 0-60 time delta between the 70D and 85D. Does that lend credence to the theory they're limiting the power of the 70s?
I'm 100% sure they could increase the power output to the motors with firmware on the 70D/60/S85/etc. I even think they still have some headroom with the 85D/90D. The 70/60's would certainly be amperage limited, however, and could never be made faster than their larger pack counterparts.
I thought this at first too, which is why I was closely monitoring the temperatures reported by the drive unit of the 60->P85 I helped with. One thing in particular is that it reports temperatures on CAN for the bus bars for each AC output phase. I compared the temperature data to data from my wife's P85 (a real from Tesla P85) and there were no discernible differences in the data. This essentially proves that the relevant components are the same. If say, the AC output bus bars were smaller, they would heat up faster under full load. If the IGBTs were smaller, they would heat up faster, etc etc. The data showed that this wasn't the case.
Further, I've seen the inside of a "standard" rear drive unit. There's nothing that suggests it couldn't handle the "performance" load.
In short, yeah... Tesla is wasting their time partitioning the two. If there is some subtle difference between them besides the sticker and firmware then it doesn't appear to be related to functionality.
- - - Updated - - -
The data on that kind of speaks for itself. We know they're the same motors. We know the normal packs with the normal fuses can output about 1300A. The 70 packs are basically "85" packs with with 14 modules instead of 16 modules. So, exact capacity aside, it's capable of 87.5% of the power output of the "85" pack. I also have second-hand info confirming that the fuses in the 60/70 packs are the same.
In short, yes I'm 100% sure the 70/70D is software limited.
