AlanSubie4Life
Efficiency Obsessed Member
So sick of people telling me I'm driving my car wrong...
Attached is a pic of the trip meter after driving today.. Never over 65, normal to slower acceleration, heat on 68. I started the day at 270 miles range View attachment 367159
That's pretty efficient driving, good job!
You say you started at 270 miles (87%). That is 270/310*75kWh = 65.3kWh
You have 0% remaining in the picture (I don't recommend doing this to your car routinely).
And your "since last charge" says you used 60kWh (actually 59.9kWh) on the drive.
So, the remaining 65.3kWh - 59.9kWh = 5.4kWh was used while parked. The Tesla numbers for the trip meter are VERY accurate and will calculate out to very close to 75kWh for a full 100% to 0% discharge but ONLY count usage when not in park.
I'd recommend being careful to not turn on the heat from outside the vehicle. If you didn't do that (or sit in park with the heat on!) it implies a significant loss for some other reason (it's 5.4kWh/242Wh/mi = 22 miles of rated range, which is far more than would be expected for normal drain.)
And limit your climate use. It's probably better to be a little chilly than run your battery to zero routinely. I would start with a higher charge too (90-95%).
