Well I went to the 1/4 mile drags in Fontana 10 days after my right hip replacement to measure my P85DL Ludicrous improvement. First I had to drive 90 miles to the Rancho Cucamanga Supercharger for a 99% fill then driving to the track 5 miles to arrive at 95%. Unfortunately the line was so long that after a 2 hour wait I was down to 91% for my first run due to heating the battery to maximum for so long. My first opponent was a new Z06. I had my best reaction time of .026 sec compared to his good .168 and did 11.326 @ only 114.48 to his 12.676 @ 121.25. The Corvette just can't get the HP to the ground without slicks. My 60' was 1.610, 1/8 7.153 @ 94.24 well below my best.
I was happy to set a new my 1/4 ET decrease by .220 sec but unhappy that I could not improve by .300 to beat the best times for P90DLs. Maybe a higher charge would have helped. The other 4 races were no contest against Mustangs and an Audi. Strangely my third run 11.461 had the highest mph of 116.92. Just for fun I tried Launch Mode on my last run with the worst results.
I just started using a cane yesterday so I am still wobbly but I could not wait till September. I will be 76 years old in 4 days.
Thanks for your efforts, but be careful not to overdo things this early after your surgery.
While you mention that you started that 11.3 pass at 91%, and Sorka points out that a higher charge than 90% would not have helped you, I wonder here that if you started that pass at 91%, what was it when you finished it.
I recall your 1/8 mile record results from your last post as
7.082 @ 96.52 and 60' @ 1.580. You mentioned that this had been done on a 92% state of charge.
Strange, the 1/4 mile trap speed difference in results obtained at 92% vs these latest results done at 91%.
Admittedly I'm grasping at straws here, but is it possible that starting at a 91% state of charge, that you were at a lower than 90% state of charge sometime between starting the pass and finishing it?
Was there a headwind or a crosswind perhaps?
The 60ft times aren't that different, .03 secs, so the time was probably not lost there. The 1/8 ET is changed .071 secs. But the 1/8 mile trap speed is 2.28mph slower than in your record run. That's significant and tells me that the car was perhaps down on power.
At any rate, 11.326 is certainly impressive. Congrats on the new time and here's hoping for continued recovery and a happy birthday.
