sillydriver
I know that a battery sitting around very hot for very long is bad, just as a battery charged to 100% sitting around for a long time is bad.
But ignoring that for a moment, and getting back to your question, is it possible that whatever degradation effects may exist could be impacted by the combination of both heat and the battery being discharged? In other words even though a hot battery sitting around is bad, is it possible that a slightly less hot battery actually discharging at a high rate of discharge is worse for the degradation aspect? If so, even if the battery gets hotter during supercharging, the max battery power option could be worse from a degradation standpoint.
If your theory is correct, then I suppose max battery power could be used for heating the battery on shore power during the winter (to improve range) without damaging it as long as you don't use ludicrous acceleration once you start driving.
