When I used the word smaller I was referring to the calipers in that their performance is not in any way inferior
You might have meant that, but that's literally not what you said.
. You affirmed that by agreeing that they both have the same stopping distance since both calipers can fully lock the wheels if needed and tires are more important factor for stopping.
No, I explained that brakes are irrelevant to stopping distance. .
You seemed to think otherwise since you mentioned stopping distance at the same time you claimed the brakes weren't any smaller and that that lack of stopping distance distance was "proof" of that- which it factually is not.
I also corrected your inaccurate claim the brakes on the P3D+ aren't are larger than those on the other Model 3s.
If you wanna keep dancing around being wrong twice by insisting you meant things other than you said that's your call I guess.
If you read further I specifically wrote about the real problem of brake fade which is heat dissipation plaguing the stock rotors for both + and - parts
And obviously the larger rotors on the P3D+ have less of this plague.
So you've now shown us one of the possible reasons Track mode would be specific to the cars with upgraded factory brakes.
Thus contradicting your own original argument.
. So far tests have shown that only the MPP rotors have stood the repeated lap fade track test. My point was that both the + and - rotors as they come stock are not good enough for the track. See the last MPP video where they tracked a P+.
I did. But not with track mode (which specifically takes steps to help resist fade with regen settings)
Plus- again, Tesla isn't going to design
anything in support or consideration you MIGHT put after-market parts on the car.
They design for what they sell from the factory.
Which, on the P3D+, is larger brakes.
So what's so great about P+ for the track:
- Calipers performance is basically the same aside from the esthetics (we agreed on that)
no, we did not.
We agreed (after I had to explain this to you) that they don't change normal stopping distance.
Which doesn't mean they "do nothing" in track use at all.
- Tires, anyone can change and are only part of the car till they ware out then its up the the owner
Sure. Though again they're going by what comes from the factory.
- Rotors only slightly larger
They're actually
much larger compared to the non + rotors than the MPP ones you seem to be in love with are over the + rotors.
But then you originally claimed they were all the same size, so....
- No suspension changes other than an insignificant drop
We don't actually know that.
We know the shocks and springs are different- but nobody has actually determined how exactly.
I suppose it's possible they just snipped .39 inches of coil off the springs or something... but it seems pretty weird they'd bother with the manufacturing and supply chain costs of different parts JUST to do that.
There is nothing fundamentally better about the P+.
I mean- other than the multiple things better about it we just went through... larger brakes, better tires, and a lowered suspension.
none of these (except the tires) will matter in street use of course- but the brakes and suspension should make a measurable difference on a track. How big is a YMMV thing though.
A P- with MPP rotors and new wheels (which I suspect most serious track users would swap anyway) is a better track car than the P+ stock.
Probably. But again expecting Tesla to design their advanced vehicle stability system around after-market parts someone MIGHT add is an insane expectation.
And these additions are about as trivial as changing an air filter. Probably easier since many have found it difficult to find and get to the air filter on a M3 (try finding it)..
Make you a deal- I'll change your air filter twice for every 1 time you wheels and brakes on my car. Should be a no brainer if your claim is true, right? (hint: it's not true)
The marketing claim about track mode BTW makes
absolutely zero sense
why?
They don't SELL P3D- any more.
So why would they do something to discourage purchase of a car
not actually for sale?
