But there is not a tamper evident seal on your actual compressor unit where they plug two low voltage AC wires to give it power. I just unplugged one of the wires and it could no longer tell my system to shut down because it was no longer receiving power. It took about 2 years for them to notify me saying something was wrong. They said they would send out a technician. I just plugged the wire back in before they came and switched off the breaker to my AC unit. So the technician just assumed it was a tripped breaker that caused the issue. Because when the breaker is flipped off, the whole system doesn't get power, including this devicewe're (voluntarily) enrolled in the SmartAC program many years back and have one of those devices mounted on the A/C condenser. And yeah there is a tamper evident seal like they have on the power meters.
Just noticed they have an IFTTT applet to push out notifications when a SmartAC event is happening. Am curious to know how many of these actually occur during the hot months
The problem is when the compressor is shut off and the system isn't producing cold air, the ducts end up getting very hot. The blower continues to run eventually blowing hot air into the house. The house will instantly jump up a few degrees. It then takes hours to cool the house back down after they turn the compressor back on. It ends up using more energy to re-cool the house than it would have used to have the system maintain that temperature the hour or less it was turned off.
A better system would be to have them shut off the whole system. But they can't do that because some people need to have the fan running for filtration.I was wondering if this ends up happening... I feel like tricking thousands of thermostats into thinking thousands of compressors are running is a weird way to solve a grid energy problem.
I find it hard to believe PG&E’s assertion that participants of SmartAC didn’t even know the things were running. To your point, if it’s super hot outside, the AC’s stopping for 30 minutes would be felt pretty quickly indoors when the air being blown around was hot instead of cool.
Also, on top of the creation of an accidental heat exchanger, He’s got older HVAC with PSC motors as well. Which means his air handers expend a lot of energy to blow hot air around.
The Leap Rewards thing made sense because the Thermostat simply wouldn’t operate the cooling system. But these weird SmartAC boxes don’t seem very smart at all.
What many utility companies have in place of or in addition to this is direct control the thermostat during a flex alert. Here they can actually turn up your thermostat remotely for a certain period of time to reduce the amount of energy being used. I ended up doing this for a couple of years after I got off the other program.
so what about people with huge houses? There are 6000+ sq ft houses near me in hot Sacramento area. They have to be in the $1000/month electrical bill. Does PG&E count the sq footage? Thats BS
Curious, when were your houses built? California and the SF Bay area having had decades of moderate weather I don’t see builders as having had the need for much in the way of installing higher rated insulation or anything but even single paned glass windows. But then decades ago the Bay’s hills were also more forested and fog was more prevalent.
I am a big fan of market choices. I am also in favor of variable pricing within reason. Texas is not a good example based on what was reported about rates during that storm. If there is some way to let those 6,000 sq ft houses pay exobitant rates for their perceived right to load the grid and use that money to build in resiliency, I am all for it.about people with huge houses? There are 6000+ sq ft houses near me in hot Sacramento area.
Yeah, another annoying factor about my location is that I'm near the border between PG&E's zone X and Sacramento's Zone S. By being further inland, PG&E allows Sacramento homes to use more energy without being considered big offender/wasters. Here's an old study/map for the zones and baseline for "normal" single family homes that were serviced with both Electricity and Gas from PG&E. In the Summer, Sacramento homes got over 36% more summertime baseline allocation than my home received due to the boundary/mapping. I'm not sure what the newest baselines look like.
But, PG&E doesn't count square footage. They simply look at the "typical" usage for a home and then apply that average as a baseline. So yeah, if you have a mega-mansion with mega-AC's then you're probably going to be paying out the nose for Summertime energy. But at that point you're also mega-rich and probably have solar+batteries.
This thread is related to Tesla energy since he is also sour on PG&E and wants Tesla solar and Powerwalls to get away from the PoCo haha.
Same here. I was on two different programs. The first was a system similar to what is described in this thread with that device on my compressor. The second was the control over my thermostat just to get a reduction off my bill each month. And I too will never do either again.I have said before I was in one of those programs before, and would never (ever, ever, ever ever) do it again, based on my experiences with it when I was in there... and I AM someone who "sets the thermostat to 80 degrees inside" in the summer, along with having solar and now powerwalls.
I will never again give the utility or anyone else any control over my AC, thermostats etc that I dont have to. No "rush hour rewards" no connecting to my nest thermostat to raise the temp (because they raise it no matter what you have it set to, even if you have it set to 80 or 80 degrees when its 110 outside, it raises 2-3 degrees, so you get punished no matter what temp you set).
I do not think for a second they told him they would actually disconnect his service if he did not comply. Thats likely just what he translated it to internally, then told you.
So your homes were built around the time of ours, early 90s here. Moved in in ‘93. We chose to be further inland away from bay for more yard space. Really wanted a 1-story but lots are so limited in size that house were left little yard space, so settled for 2-story. Our master bedroom and husband’s office of course gets the hottest sun. Planted a palm on that side a few years ago that should shade the stucco walls for his office in a few more years (thankfully that side yard wide enough and palm roots won’t damage hardscape or foundation or underground pipes). We did buy our house with a room downstairs that could be a bedroom with thoughts of cooler Summer sleeping but haven’t used it for that yet. Installed solar attic fan but never saw as much cooling effect as we hoped so don’t advise those. In 2018 I tried living with thermostat at 80 for a few months using fans in upper bedrooms but it was too hot. I’m more heat sensitive and we found we didn’t sleep but tossed and turned all night. No wind most nights. After that year said we had to do something. The wildfires and PSPS really were the final straw.These houses were built in the 90's. We're in Contra Costa south of Mount Diablo. I don't think the construction is that bad (the windows are ok), and the ducting is ok.
The issue is more the general architecture of the house is stupid. Like we have large roof panes that have virtually no attic (only vaulted ceilings). So imagine a two story house with vaulted ceilings as just one big gigantic attic. Cooling it is a nightmare due to the volume of air inside. If we could get some big trees in the south-side of the yard, the shading would be awesome. But this is California; we don't have the huge lot sizes or flexibility to just start planting big azzz trees like what I'm used to in other states. The ducts themselves are also poor candidates for creating zones so we're stuck with a 3 ton upstairs and 3 ton downstairs.
Unfortunately the side of the house that would be amazing for solar also points NorthSome homes in this subdivision can get 12 kW+ systems in, and I'm super jealous hah.
Now with solar I'm no longer have them control my thermostat. Even with solar I still set my AC between 78-82
In part the Bay Area’s general plan (ABAG) to accommodate and expand the growth of new homes in cities here I think plays a big factor. Utilities can’t keep up with added expansion. People don’t want more power plants/substations in their cities. Older utility equipment from what I understand from some threads on here doesn’t mesh well with increased number of buildings with solar panels (commercial and residential). This planned population expansion hasn’t only affected electricity usage (which is being increased by preventing natural gas installs too and eventually impacted by EVs in numbers) but water too. The community I live in has to approve additional housing units, no choice, that some developers want to build despite the fact we’re in a drought and we have water restrictions everywhere. Let’s face it we are all going to pay one way or another.You're kind of touching on why the power companies want to repeal net metering. The PoCos argue that the vast majority of the 6,000 sq ft homes get the benefit of being served by the grid, but those same homes are the ones that invested in solar to reduce their monthly energy costs. This reduction of money from the uber-rich shifted the burden/costs to everyone else who didn't have solar or batteries.
So the big azzz home gets the benefit of grid resiliency and has the ability to use the grid for net metering, but the big home isn't paying its fair share to maintain that huge/expensive grid through exorbitant monthly rates for generation and transmission. The big azzz home becomes the evil entity that shifted more costs onto disadvantaged and middle-class rate payers. PoCo's want that one big home to incur a $1,500 monthly electricity bill (to be paid to PG&E) so that 99 other bills can be reduced by $10.
But we know this isn't how solar works. The PoCo's tactic of painting millionaire mega-homes as the "problem" is BS. The average middle-class homeowner who is just trying to figure things out is the one getting smashed. Most solar customers are just middle class households.
PS, I'm not in a gated subdivision with 6,000 sq ft homes. This is my first home. I don't have some trust fund or wealth manager on speed dial. I simply cannot grasp why the PoCo decided to make it their business to get into my business over and over and over. And the concept of the PoCo basically strong-arming my neighbor into installing some weird energy boxes is just so weird to me. But I guess most people think this is normal/rationalized behavior from the PoCo?
Yeah - I think there should be options, and I think it is great that utilities offer these programs - as options. I also limited my statement to my location (where solar adoption is not so high to see the same duck curve issues as elsewhere.) And, I did get batteries, so if the utilities out here signal they need support during that time by bringing in TOU rates, I would take advantage. So far, they have not done so (but have been piloting TOU rates.) As I have commented before, it is interesting to watch from afar as California grapples with these issues, on the hope that things will be worked out a bit better by the time we have to deal with them on the other side of the country.I would agree for the most part. However solar is intermittant and it is precisely after the sun goes down that the grid needs help by having people shift loads. A/C shutoff is cheaper than batteries to solve the ramp up in demand. I can afford batteries and others are happy to pay penalty rates but there needs to be an affordable solution for some who want that choice.
Based just on how you wrote that, my guess is he likely had a choice — the device or service interruption, but he felt he wasn’t really given a choice. Could be wrong but I can see him feeling forced into it.
Long gone are the days of cranking the A/C down to the lower 70s.
I was shocked when my husband’s Cupertino apartment only had “noisy” single paned windows. Don’t think we thought the cold/heat as big of an issue back then compared to the sound transmission. When we were looking to buy a new construction house in a more interior area in the Bay, we were looking for at least low-E double paned windows and went with the extra insulation option offered by the developer for the attic and between floors. We talked about but still haven’t done anything to have our garage doors insulated. With our solar and PW equipment inside one of our garages we really should now. That garage faces northwest and no windows so not quite as bad but late afternoon it gets pretty hot in there.
While we haven’t had a full year of use from our solar system, we think on hot days the panels are cooling our house by shading the SE and SW roofs which would be an added bonus.
